LG 55lm6400 Bad panel or main?
  • topfli8979
    • Oct 2012
    • 311
    I picked a LG 55lm6400 that has vertical lines on the right side of screen. Will get pictures up shortly. The tv powers on automatically once plugged in and there is no picture,menu nothing. Just prelit screen with 4 vertical lines on right side. The standby light is always on, does not respond to remote or power button on tv. I can unhook the lvds cable on the y drive boards, and then there is no lines on the screen anymore on either side with right or left lvds unhooked. What's the chances the main is bad?
  • topfli8979
    • Oct 2012
    • 311
    Re: LG 55lm6400 Bad panel or main?
    Here is a picture.
    • MagicSmoke
      • Feb 2011
      • 275
      No response from buttons or remote sounds like a mainboard problem. Try reseating all of the LVDS cables first. If that does not change anything then main is suspect.
      • topfli8979
        • Oct 2012
        • 311
        Already cleaned/reseated lvds few times no change. I'm thinking main also just wanted a second opinion.
        • topfli8979
          • Oct 2012
          • 311
          UPDATE! Found a lg 47lm series with busted panel local. Bought just the main, TV is back up and running perfect.
            Very surprised... panel was OK? Nice fix. Maybe I'm too cynical but I would have called panel any day.
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
            • triplefour
              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
              by triplefour
              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
              tcon is built into mainboard.
              Only one cable goes to panel boards.
              there is a cable from one panel board to the other that links them.
              cost cutting measure that results in us having harder time to diagnose.
              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
              07-28-2022, 07:59 PM
