Panasonic Plasma--Black Screen--Solid Red LED
  • j.robinson389
    • Feb 2015
    • Montgomery
    I have a 50" Panasonic plasma. Model Number TC-P50S30.
    A few days ago, I was watching it, and like someone unplugged it; the TV went out. It would do nothing except display a solid red power LED light. No fault codes.
    After playing around with it I held the power button in for about 10s and then I started to get 14 blinks. Next I started doing some research and found this guide. After following it I found that the Vsus(p11/White was shorted) after following the flow chart it said to replace SC board. But as I read further into the guide I found another flow chart to trouble shoot the solid red LED condition.
    The flow chart states that after unplugging the listed connectors (SC2, SC20, SS11) and I get 8 blinks, based on this it says to replace the A-board.
    So basically my question is where do I start? I am leaning towards replacing the SC board first, since I can simply go from a solid red LED to an 8 blink LED by unplugging SC2, this tells me the problem most likely is within the SC board correct?
    On the other hand this all may be a null point since I am having trouble finding either an A-board or SC Board at all.
    Thanks for the help in advance,
    Jake
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma--Black Screen--Solid Red LED
    basically check sc2 if shorted then Sc board which can be repaired. I did a Th-p50U30a which has the same board and got that going with just replacing 4 x 30f131 IGBTs. theres kits with those , plus the 2 diodes, 4 resistors and new screws.
    My board was loose and screws and board had arc marks also burns on the chassis itself.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
