Magnavox 50 mf231d37
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Magnavox 50 mf231d37
    Verified version of logic board..it is correct.
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      What if the SSB (Main Board) somehow went bonkers and thinks it is driving a 32 inch screen instead of a 50? Or possibly the screen alignment is off? Read the attached information. There is a label inside the chassis..I do not have the original remote, but very close.
      • MagicSmoke
        • Feb 2011
        • 275
        Most of the time the factory remote is necessary to access the service menu.
        Have you tried entering the 062598 menu sequence to see?
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          I will try it..
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Does not work with the Phillips remote I have..as soon as I press a number key the set comes on. Will replace logic board first...then maybe spring for factory remote.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              With factory remote, entered Service Alignment Mode (SAM). As soon as main alignment screen came up, screen went blank. I think something on the SMPS board gave up the ghost..I now have red light blinking four times. No LED now on logic board. Only one green LED on SMPS where I previously had two. When I cycle power, before it goes off on error I measured all four main voltages on label and all show good? If I unplug logic board, no blinking red light error but no joy of course. I have another logic board but it is clear that going into SAM whacked something on SMPS. I have it on the bench..have not found any failed components yet. In the pic, you can see the two green LEDs in lower right section..LED8002 and LED8001..Previously both were lit as well as power to logic board..now only LED8002 is lit until she shuts off on the four blink error. checking fuses now.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                Diode D8049 shows a short..any hints where else to look?
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  D8043 is shorted as well as Q8001 and Q8003..taking diodes out of circuit to see if its diodes or MOSFETs.
                  • ahmedtou
                    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                    by ahmedtou
                    help me please
                    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                    I will share all the details with you, including the disc information.
                    Code:
                    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                    Current Profile: BD-R
                    Disc Information:
                    Status: Empty
                    State of Last Session: Empty
                    Erasable: No
                    Free Sectors: 12,219,392
                    Free Space: 25,025,314,816 bytes
                    Free Time: 2715:27:17 (MM:SS:FF)
                    Next
                    08-27-2025, 08:49 AM
                  • tonybig10
                    Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                    by tonybig10
                    Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                    the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                    03-07-2025, 01:03 PM
                  • DeanWy
                    WD Sentinel DS5100 (NAS) boot issues
                    by DeanWy
                    I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                    It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                    There...
                    07-30-2024, 04:13 AM
                  • modtool
                    Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                    by modtool
                    Dear members,
                    I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                    I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                    The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                    When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                    01-15-2024, 08:56 PM
                  • gurj1979
                    Surface Laptop 1769 SSD Failed KUS040202M-B000
                    by gurj1979
                    Hey guys,
                    I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
                    These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
                    AliExpress has this but it's expensive.
                    Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
                    Or which NVMe can I remove it from ?
                    02-17-2025, 04:02 PM
