Samsung UE32F5000 (UK model) with no display. Power supply is OK.
  • samwibble
    • Feb 2015
    • 6
    I have a Samsung UE32F5000 (UK model) with the dreaded standby light blinks 5 times and no display. Using a flashlight I can see a message on screen when I push the menu button, so I guess that means the main board is OK. I've tried replacing the power board but still get the same thing. I presume therefore it must be the inverter, but I can't see how on earth I get to it with this model. The connector from the power board just goes straight into the panel (on the left).
    Any help would be much appreciated. I've attached a photo. I don't have any multimeter, sadly.
    Re: Samsung UE32F5000 (UK model) with no display. Power supply is OK.
    No inverter in this set. It is LED backlit so power supply will generate LED drive current.
    99% sure you'll have an open circuit LED in the LCD panel - a pain to replace as the panel itself has to come apart. Becoming a -very- common issue with Samsung sets.
    • samwibble
      • Feb 2015
      • 6
      Thanks for the fast reply. I was worried you might say something like that! Is it very awkward to fix?
      • samwibble
        • Feb 2015
        • 6
        OK, I've taken the panel apart and can see five Sharp LED strips. Presumably the problem is in one of these?
          You can try testing each with a 3V coin cell (CR2032) battery.
          • samwibble
            • Feb 2015
            • 6
            Ah, right, how do I do that? Sorry this is all new to me.
            • khalednabil
              • Dec 2013
              • EGYPT
              dears
              FYI, this issue because back light is defect
              kindly please open back light and check will find some line is short
              • thoma
                • Sep 2012
                • 268
                LED Stripes for LED TV
                http://www.shopjimmy.com/tvs/tv-led-light-strip
                http://www.ebay.com/bhp/led-backlight-strip
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Are any of the leds burned? Is it a 5 double blink?
                  • Stray
                    • Aug 2015
                    Hi guys, sorry to hijack. Having the same problem with my TV of the same model.
                    No picture but sound, can see the imagine in a dark room if you put a torch up to it. I'd previously read that this was like be the inverter but I've opened it up and similar to Sam I can't see an inverter.
                    Completely new to this but it's out of warrenty so I thought I'd have a go at fixing it.
                    Can you please advise me what to check next?
                      Are you sure you are talking about the same model? The Samsung UE32F5000 uses LED for backlights so it does not have INVERTER board which is used for TV that has CCFL TUBES. See post 2.
                      • Stray
                        • Aug 2015
                        Yup I can confirm that when I opened it up that it had NO obvious inverter board.
                        Model Code on the label is: UE32F5000AKXU and as far as I know it's the UK model.
                          It does not use inverter board because it does not use CCFL, it uses LEDs for backlights.
                          So you should upload pictures for your TV back side that shows all the boards first.
                          P/N of the power supply board BN??-?????
                          • MIM
                            • Aug 2015
                            Hi guys,same TV, same problem. 5 blinks no image but I have sound. What is the problem ????? Pls advise me .....
                              Please up load the pictures of YOUR TV, we will need to see the whole backside of the TV that shows ALL the board and then the pictures of each board.
                              • MIM
                                • Aug 2015
                                https://www.badcaps.net/forum/attach...2&d=1423759109
                                  I ask for YOUR pictures because I do not know which board revIsion you have in your TV, same TV model can have more than one version used in the TV.
                                  What are the P/N of YOUR boards?
                                  and 'and then the pictures of each board.'.
                                  So far none of the people here even offer the give out the P/N of the boards after I requested.
                                  • MIM
                                    • Aug 2015
                                    It doesn't have an inverter board
                                      I already said that, again it uses LED backlights so NO INVERTER. How many times do I need to repeat that?
                                      Tom66 also said that:
                                      Good luck troubleshooting, I am out.
                                      18 posts and still no pictures of each boards, no P/N of the boards.
                                      • MIM
                                        • Aug 2015
                                        How can I measure the the LEDs stripe ?
                                          03-31-2024, 02:12 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          07-01-2024, 06:34 AM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
