Hitachi 42EDT41A Glitzy Solarizing- ZSUS??
  • Michale32086
    • Nov 2011
    • 1453
    I came across an older Hitachi...
    It's old and it's heavy... Don't want to put much work/$$$ into it..
    http://sjfm.us/temp/42EDT41A.3gp
    If it's just the ZSUS board, it might be worth fixing... If it's possible/likely other boards are bad, not so much..
    What's the chances of me actually getting lucky here??
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Hitachi 42EDT41A Glitzy Solarizing- ZSUS??
    That kind of looks like a YSUS issue to me. How is vscan? Is it stable while its doing this?
      Agreed on Y-sus fault. I believe these sets use Vw for Vscan and Vy as Vy, though I have not worked on one for a long time...
      • Michale32086
        • Nov 2011
        • 1453
        I just knew it wasn't my day to get lucky..
        I gots to pick up the wife from work in about 20 mins..
        I'll get it on my bench first thing in the morning and check the VS..
        Thanx for the input.. Very much appreciated..
        • Michale32086
          • Nov 2011
          • 1453
          What the hell, I have at least 20 mins
          Here's what I have accessible on the YSUS...
          VSCW, VY and V-SETUP
          I am assuming the VSCW is the VS/VW..
          I also assume it matters what side of the resistor I clip on the + probe??
            Is this an LG panel inside?
            • Michale32086
              • Nov 2011
              • 1453
              LGE PDP 040228
              Model 42V6
              • Michale32086
                • Nov 2011
                • 1453
                That's the part number on the YSUS board..
                  Voltages will be measured across those resistors.
                  • Michale32086
                    • Nov 2011
                    • 1453
                    I knew that..
                    • Michale32086
                      • Nov 2011
                      • 1453
                      VSCW started at 121v at power up, then gradually went down..
                      VY started at -76v at power up and gradually went up..
                      The Label says VS 160V...
                        Ignore polarity for most power supply testing.
                        Hypothetical example. Power supplies generally have a polarised output capacitor and an output rectification diode on the transformer side.
                        So, what would happen if the supply had -200V on it instead of +200V? And this was somehow a continuous operation. Three things:
                        a) the diode would be rapidly damaged by the capacitor discharging
                        b) the capacitor would violently bulge and vent. The chemical reaction inside the capacitor vents hydrogen peroxide which really stinks up the place.
                        c) the transformer, driver FET and control logic would probably emit the magic smoke, which would stop them working (as electronics work on smoke - if the smoke leaks, they stop working)
                        I'm assuming that none of these have happened. If so, ignore polarity for now.
                          Vs != Vscw.
                          I have not seen a Vs that low before!, sure it's not 180V?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            sounds like the low vs causing the picture to momentarily want to drop out. Try with Y & Z boards disconnected from power supply does the power supply maintain vs and what is the voltage?
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Had to leave the unit at the shop... I'll jump on it first thing in the AM, EST.... I'll also confirm the VS stuff....
                              Thanx for all the input.. I'll follow up...
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Yep, haven't seen any evidence of this..
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  OK, measured VA and VS off the connectors coming from the Power PCB..
                                  VS shows 192V
                                  VA shows 65.6V
                                  Both are in keeping with the tag on the display...
                                  VS=190V
                                  VA= 65V
                                    Is Vs stable when picture glitches? Check on Y-sus and Z-sus too - could be bad connection.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Seems to be stable. Holds at 192v +/- a volt or so...
                                      Both Y and Z show stable 192 +/-
                                        Worth checking other voltages then and see if they drop out, including Va.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
