Darfon V070
  • torentino
    • Feb 2014
    • 22
    • Slovenia
    Darfon V070
    sorry if mentioned before. I stumbled in an old 27" tv, model LCD27S10, MB Vestel, maker Gorenje, with inverter Darfon V070 4H.V708.001/05 going down after some seconds. Checked CCFL, nothing dramatic, they lit more or less the same. The voltage on OZ960 pin 2 (OVL)jumped to high before invertershut off, so I put 100K resistance between pin 2 and ground, now voltage is 2,10V, tv is working flawlessly.
    regards
  • ChattFix
    LG 86UK6570PUB 3 Red Blinks
    by ChattFix
    Hey Everyone, I have an LG 86UK6570PUB that wont turn on. Power light blinks 3 times. Tested voltage from power supply to main board and it is sending the correct voltage. When testing LEDs I have 1st strip at 210v 20mA, 2nd strip goes from 208v 20mA to 214 40mA. I'm assuming the LED strips is the issue. Anyone seen this before or can point me to something else to check?
    01-15-2025, 11:19 AM
    Protection Pin Shutdown in PWM Controllers & LCD inverters
    How to remove the protection of the inverter - several ways to protect shutdown in popular PWM controllers, LCD inverters.
    When repair and diagnosis, it is often necessary to check the individual
    inverter circuits - power converter lamps illuminate the LCD panel.
    Carry out the necessary measurements is sometimes not possible, the
    generation of breaks for various reasons, for example because of the
    imbalance in the loads.
    Together, artists and researches different options for the repair of
    conferences were blocking inverter protection in order...
    11-06-2024, 04:18 AM
  • Dannyx
    Asus G512 no power (BQ24780S problems)
    by Dannyx
    Good day folks. It's been a while since I repaired a laptop, so here's a challenge: a friend of mine asked me to take a look at an Asus G512LI killed by the liquid metal that got smeared all over the board when someone tried to clean it (I'm not blaming it on him - could have been someone before him). I was able to clean it enough to get it going on my own, without any help and thought I was all done, but then I ended up breaking it again
    See, the battery wasn't charging and the laptop wouldn't start on battery either. If you were to start it on AC and THEN unplug the charger,...
    10-16-2023, 11:26 AM
  • Crystaleyes
    RiddleMeThis - What smokes but doesn't burn?
    by Crystaleyes
    hope life is treating you well.
    I have a question, as I am genuinely puzzled.
    There is this old Tektronix 2215 scope which has been laying around for some time, that I knew had some issue, but couldn't remember what...
    Anyways, last night, I thought I'd give it a look, as space is needed, so put it on the bench and plugged it in.
    The CRT had a terrible trace which only filled half the screen and didn't seem to respond much to any of the controls, so I decided to give it 15 minutes to warm up whilst I cleared up the bench...
    07-02-2023, 01:58 PM
  • Bigfoot
    Samsung TV UN60J6200AF No Display + No LED
    by Bigfoot
    Hi guys
    I'm working on similar Samsung TV UN60J6200AF.
    When I plug in power cord, the red light lights up, and flashes, then turns off.
    I measured on the power supply board, and even without pressing the power on zbutton in getting on CNM803 (which goes from Power supply to Main board):
    UD = 2.3V
    PMW_BLU4 = 3.3V
    PS_ON = 4.4V
    A13V = 12.75V
    I looked at the manual and all the voltages are correct.
    When I unplug the main board from the power supply, LED lights are supposed to come on. However, non do come on.
    06-20-2023, 10:24 PM
