Polariod le-22gbr+dvd
  • sordids999
    • May 2013
    • 2161
    hello
    tv works fine but when using inputs scart/hdmi it keeps showing a message asking you to ring a helpline
    i have been searhing online and there seems to be a update to fix this but cant find any firmware updates
    or possible EEprom fault
    has any guys come across this problem before ?
    thankyou
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Polariod le-22gbr+dvd
    Replace the epprom on the main board, these boards the epprom always seems to corrupt because the software is barly functional. I bet that if you replace it the tv will be back to life.
    • sordids999
      • May 2013
      • 2161
      anyone know where i can get a eeprom though
        Before you try replacing EEPROM/flash memory IC...
        Press INPUT 2580 on the remote (also try INPUT 3690/4725) to access service menu
        Select "Factory Reset" or similar option, see if that works.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I have tried that on these umc built sets never works the epprom is most of the time always dead
          • sordids999
            • May 2013
            • 2161
            ok ill have to try and get a remote did not come with one unfortunately also tried my one-for-all remote but no good
            • sordids999
              • May 2013
              • 2161
              ok so out of interest how do i find the correct eeprom anyway ?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                First what is the full model number of the board ?
                • sordids999
                  • May 2013
                  • 2161
                  Cv9202l-a -11 121116
                  • sordids999
                    • May 2013
                    • 2161
                    From what i think it reads Winbond 25Q32BVSIG eeprom found some on ebay but they need programming i think ?
                      Yes, will need programming.
                      It's a serial/SPI flash for the TV's software. EEPROMs are different and generally only store configuration. Most TVs will work with a blank EEPROM, as they will reset it with new data.
                      • sordids999
                        • May 2013
                        • 2161
                        so correct me if it read your reply wrong i can order and fit a new eeprom and the tv will reset with new data ?
                          No....This is an SPI/serial flash. Stores software that the TV runs. So it won't work unfortunately.
                          If it *was* an EEPROM, that might work (on many sets it does)
                          • sordids999
                            • May 2013
                            • 2161
                            Ok thanks tom so the only option is a replacement board ?
                              Yeah, pretty much - hardly worth it for a 22" set. Still, do try the reset first.
                              • SidneyCanadas
                                93C46 and 93C56 EEPROM
                                by SidneyCanadas
                                I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                06-14-2023, 01:16 PM
                              • dmccul2698
                                Pioneer DEX-P99rs "No EEProm " diagnostic code.
                                by dmccul2698
                                Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                                1). Understand the schematic and check the connections between the EEProm and DSP
                                2). Check the functionality of the EEProm
                                I don't know if this is the unit's problem but it's a place to start.
                                I have little to no electronic experience...
                                04-08-2024, 05:32 PM
                              • edgarmg15
                                Damaged EEPROM on TV Vizio E320-A0
                                by edgarmg15
                                Hi everyone
                                I´m trying to repair a TV Vizio E320-A0 that I found in the street
                                The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                                The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                                So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                                11-19-2022, 03:46 PM
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • AlexGsmMaster
                                Eizo CS2740 eeprom dump, search.
                                by AlexGsmMaster
                                Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                07-26-2025, 03:24 PM
