Strange HDMI problem with Vizio M3D421SR
  • twoj
    • Feb 2015
    • 25
    I have been trying to troubleshoot my M3D421SR. Its been good for ~3years. Few days ago the signal from BluRay and Xfinity cable box over HDMI connector (does not matter which) do not display anything on the screen and I get 'Not Support!' message with the BluRay. The strangest thing is that when xFinity box boots up, I can see 2 low res screens that it shows while booting. One is 480 and the other 720. My TV reports that in the upper right corner.
    However my laptop, has no issues rendering 1080 screen on the same HDMI ports. I also tried different cables, 4 of them, same problem. None of them work with BluRay and Xfinity, but no problems with my laptop.
    Component connections work fine as well, and so does Netflix via smart apps?
    I tried doing the 'soft' reset with pulling the power cord out, and holding the the power switch down. No success. I also did the factory reset via the menu. No dice.
    I have contacted the ebay rebuild service, but they said that there is nothing to fix since I still had no problem displaying other signals on the screen.
    I'm suspecting a handshake problem between protected HDMI devices and the TV.
    So, I tried to get a new mainboard, by the one I need: TXBCB2K00603Q is nowhere to be found; so I ordered TXBCB2K00605Q instead.
    And this is when I found this forum!
    So my real question are:
    1) Is mainboard replacement the only way to fix this TV?
    2) Can I safely try using TXBCB2K00605Q instead of TXBCB2K00603Q?
    I appreciate you time and help.
    Regards
    • 12098
    • U.S.
    Re: Strange HDMI problem with Vizio M3D421SR
    wrong post
      • 12098
      • U.S.
      did you try a reset? Use the Arrow buttons on the remote to highlight CLEAR MEMORY/FACTORY DEFAULTS or Reset TV to Factory Defaults and press the OK button. Enter the parental control PIN (if you have never changed this, it is 0000) and press OK on the remote. Do not press the Power button.
        • 12098
        • U.S.
        https://www.youtube.com/watch?v=HSPI5LoVLhw
        • twoj
          • Feb 2015
          • 25
          Yes. I tried that no success. I also wiped out my apps :-) just to be sure.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I have this with a toshiba 32av55d (or somthing) cant find out whats causing the issue, tried new epprom all the regulators that run the hdmi are fine no badcaps. Swapped out the mainboard and all works I have come to the conclusion that one of the vga chips on the board have failed.
            • twoj
              • Feb 2015
              • 25
              But, why would my laptop work over the same HDMI ports? It has to be something with the 'protected' vs open HDMI signal right? So then it has to be a problem with decoding hardware?
              Either way mainboard replacement is the way to fix it. How about the different mainboard #'s; Should I worry about that?
                • 12098
                • U.S.
                maybe try a firmware update, if ones available.
                • twoj
                  • Feb 2015
                  • 25
                  No firmware available. No other internal diagnostics available either.
                  You can check the status of the current screen via 'INFO' function. And it does report that there is something there, giving you the resolution of the signal coming in.
                  STRANGE ?!?
                    • 12098
                    • U.S.
                    if I understand correctly, your laptop works on the same hdmi tv ports, then I cant see how its a mainboard issue.
                      • 12098
                      • U.S.
                      can you set your tvs hdmi settings to all resolutions?
                      • twoj
                        • Feb 2015
                        • 25
                        No I can not, they are auto sensing/detecting.
                          • 12098
                          • U.S.
                          try unplugging all video connections, unplug tv for 15 minutes, plug it back in plug one hdmi source maybe blueray, nohing else, then turn tv on, dont turn tv on before you plug bluray hdmi in, see if that works.
                          • twoj
                            • Feb 2015
                            • 25
                            Well, other components work correctly. The only problem is the HDMI when it receives a 'protected' or 'encrypted' HDMI signal (I'm speculating here, and could be wrong). At least this would explain why my laptop works. So it this is the case, whatever component actually performs the decryption is faulty.
                            • twoj
                              • Feb 2015
                              • 25
                              OK... Give me 16 min.... :-)
                                • 12098
                                • U.S.
                                then maybe just try xfinity by itself, or if the above works, try adding xfinity, read something about hdmi dont like being plugged in while tv is on.
                                  • 12098
                                  • U.S.
                                  • twoj
                                    • Feb 2015
                                    • 25
                                    OK. Did that. And no display. Just black screen. TV says 'Retrieving Data...' then flashes resolution @ '1080' and screen stays black. You can see backlight on, so its getting something.... but no real picture
                                      • 12098
                                      • U.S.
                                      something strange for sure, maybe call xfinity tech. support.
                                      • twoj
                                        • Feb 2015
                                        • 25
                                        Yes. Thought of that, but if my BluRay stopped working at the same time, it can not be xfinity problem exclusively. That is why I'm pointing to 'encrypted' HDMI vs clear HDMI signal. Can someone else who know their stuff disprove this?
                                        I thought it was 1080 problem, so I kicked down xFinity + BluRay to 720 with NO success. And I can render 1080 screen from my laptop! Frustrating!
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Pinky Deepak
                                          Vizio M60-C3 Left Edge problem
                                          by Pinky Deepak
                                          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                          09-27-2024, 05:11 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
