I have been trying to troubleshoot my M3D421SR. Its been good for ~3years. Few days ago the signal from BluRay and Xfinity cable box over HDMI connector (does not matter which) do not display anything on the screen and I get 'Not Support!' message with the BluRay.  The strangest thing is that when xFinity box boots up, I can see 2 low res screens that it shows while booting. One is 480 and the other 720. My TV reports that in the upper right corner.
However my laptop, has no issues rendering 1080 screen on the same HDMI ports. I also tried different cables, 4 of them, same problem. None of them work with BluRay and Xfinity, but no problems with my laptop.
Component connections work fine as well, and so does Netflix via smart apps?
I tried doing the 'soft' reset with pulling the power cord out, and holding the the power switch down. No success. I also did the factory reset via the menu. No dice.
I have contacted the ebay rebuild service, but they said that there is nothing to fix since I still had no problem displaying other signals on the screen.
I'm suspecting a handshake problem between protected HDMI devices and the TV.
So, I tried to get a new mainboard, by the one I need: TXBCB2K00603Q is nowhere to be found; so I ordered TXBCB2K00605Q instead.
And this is when I found this forum!
So my real question are:
1) Is mainboard replacement the only way to fix this TV?
2) Can I safely try using TXBCB2K00605Q instead of TXBCB2K00603Q?
I appreciate you time and help.
Regards
Regards
