Strange HDMI problem with Vizio M3D421SR
  • nomoresonys
    • 12116
    • U.S.
    Re: Strange HDMI problem with Vizio M3D421SR
    no problem, its been a distinct pleasure for me, trying to help you, I doubt if anyone here is going to hold your hand thru solving your problem, its your tv, DO THE WORK.
    • twoj
      • Feb 2015
      • 25
      I hope I did not offend you. I did not mean to. My frustration comes from the problem with the TV that partially works. You have been nothing but very helpful for me to trying to solve this problem. Thanks for all your suggestions.
      Would you know if the main board # have to be exact match?
      Regards.
      • twoj
        • Feb 2015
        • 25
        OK! I got the new board CBPFTXBC02K006005Q and I replaced it.
        IT WORKED! :-)
        Thank you and good luck! If anyone is interested in my old TXBCB2K00603Q let me know.
        • lwilli201
          I have the same problem. I corrected it with a HDCP complient HDMI splitter. An HDCP complient HDMI switch should also work. Much cheaper than a new MB if you can find one.
          • twoj
            • Feb 2015
            • 25
            Are you kidding?!?! That is awesome! :-)
            Do you mean something like this: http://www.amazon.com/SANOXY%C2%AE-s.../dp/B003UYOEMI
            If mine ever goes again... I'll try this.
            • lwilli201
              #26
              That is it. Worked for me. I got this TV for $50.00 and this $15.00 switch got it working great. Just curious, what is the firmware version on your tv? Mine shows version 3.12.16.
              • twoj
                • Feb 2015
                • 25
                That is what I have as well 3.12.16.
                • rajbot
                  No Power problem with Vizio E60-E3
                  by rajbot
                  Hi all:
                  I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                  I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                  On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                  03-22-2023, 08:09 AM
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Pinky Deepak
                  Vizio M60-C3 Left Edge problem
                  by Pinky Deepak
                  I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                  Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                  09-27-2024, 05:11 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
