LE 42LE4500 Keeps restarting Help
    LG 42LE4500 Keeps restarting with a click from the main board
    My one works fine but turns it self off after about 5 mins and restarts over again and the keep restarting . Does anyone now that I should check first on this fault or had this problem aswell
    Re: LE 42LE4500 Keeps restarting Help
    Does anyone now where to start . the click is coming from 2 black relay type parts near the power input . which makes me believe that something is breaking down when hot and the relay type thing are triping shouting down the board to prevent damage to LG 42LE4500-ZA PSU EAY60803202
      The relays aren't a protection device. My guess would be a main board fault. If you can get into the service menu you can read shutdown cause reasons there. It will help you determine the fault cause.
      The 42LE5400 is similar, this service manual may help:
        note: I moved the irrelevant post.
          Thanks tom . Just got to find out how to get into the service menu on this model . cheers
