Pc43f4500
  • sordids999
    • May 2013
    • 2152
    Pc43f4500
    hello guys
    another tv im looking trying to fix
    to the left of the screen in the middle im getting mal-charge a small line of red-green speckles and sometimes top left a batch of green speckles,the tv keeps restarting i was told by the previous owner but she only was using aerial connection(which i dont use) but i have tried scart and hdmi nothing yet
    i have uploaded pictures in the service mode via SVC and i have loads of failures
    my readings are the following:
    VS 205 Volts
    VA 56 Volts
    VSCAN -187 Volts
    SVT_VS 205 Volts
    SVT_XOUT 81.6 Volts
    legend readings on PSU
    PIN 1 : 15V 15.1 Volts
    PIN 2 : GND
    PIN 3 : OUT-A 79.1 Volts
    PIN 4 : OUT-A 79.1 Volts
    PIN 5 : OUT-A 79.1 Volts
    PIN 6 : VS 205 Volts
    PIN 1 XS 0.0 Volts
    PIN 2 DRV_RESET 0.04 Volts
    PIN 3 XG 0.67 Volts
    PIN 4 VS_S SIGNAL 1.53 Volts
    PIN 5 DS_RESET 0.04 Volts
    PIN 6 VS_ON 3.23 Volts
    PIN 7 GND
    PIN 8 GND
    PIN 9 5.3=5.16 Volts
    PIN 10 5.3=5.16 Volts
    PIN 11 VA 57.8 Volts
    PIN 12 VA 57.8 Volts
    PIN 13 GND
    PIN 14 STBY=5.20 Volts
    PIN 15 PS_ON 0.03 Volts
    PIN 16 15.0=15.39 Volts
    PIN 17 GND
    PIN 18 5.3=5.19 Volts
    PIN 19 5.3=5.19 Volts
    PIN 20 5.3=5.19 Volts
    PIN 21 GND
    PIN 22 15.0=15.39 Volts
    Re: Pc43f4500
    Can you upload a photo of the full screen showing the defect? On a picture or normal TV (try using Self Diagnosis feature in user menu)
    • sordids999
      • May 2013
      • 2152
      Re: Pc43f4500
      https://www.youtube.com/watch?v=B12h3q2MiCs
      hope you can see this video with the fault tom becuase it goes after 5 mins roughly with just a slight line of pixels showing
        Re: Pc43f4500
        That's an odd fault not seen that before, would be tempted to suggest Y-buffer (or Y-main - all in one board)
        As for the FAILUREs, have you tried a factory reset?
        • sordids999
          • May 2013
          • 2152
          Re: Pc43f4500
          tried a factory reset but still getting the failures
          • sordids999
            • May 2013
            • 2152
            Re: Pc43f4500
            tom if i turn down the Vscan pot down so the voltage measures -181 but on the panel it should be -190 would this matter because the mal-charge is gone at -181 ?
              Re: Pc43f4500
              It should be fine; that's not the first time I've seen a Samsung with maldischarge issues despite being very new. But, I would try lowering Vs a few volts (max 5V), and see if you can set Vscan back to factory, or you may see other effects on the image.
                Re: Pc43f4500
                The failures -may- be normal; it could simply mean they haven't been tested yet. I'd check everything else seems to be working. I seem to recall that most Samsung show "T-con USB download: Failure", regardless of fault.
                • sordids999
                  • May 2013
                  • 2152
                  Re: Pc43f4500
                  ok set VS to 198 volts but Vscan is still -181 volts but images look ok at the moment
                    Re: Pc43f4500
                    198 is a little low you might get issues on high brightness. Make sure you get no pink tint on a white screen (use Paint to make full colours, or service menu test patterns)
                    • MisterAIL
                      PS5 digital / No Power / No Beep / Good power supply
                      by MisterAIL
                      Brought a non functionnal PS5. Apparently only a bad PSU...
                      No beep, nothing.
                      After some tests i found this :
                      - PSU is fine (12 volts stable)
                      - 12 volts line is shorted
                      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                      - By the way, nothing change. No signal, no power, no beep.
                      Mesuring all rails with my workbench psu (12 volts input)
                      - 0.00 amp drawing
                      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                      03-12-2024, 03:24 PM
                    • Mcfeetroy
                      Fishing bite alarm drains battery
                      by Mcfeetroy
                      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                      08-01-2025, 03:52 AM
                    • BTubbs200
                      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                      by BTubbs200
                      Dell Latitude 5420 P137G
                      Board: LA-K491P REV A01
                      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                      Board seems to have no shorts, all power rails are fine and show high resistance.
                      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                      01-24-2025, 08:15 PM
                      MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                      by sam_sam_sam
                      I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                      I open it up to find non brands name capacitors in it
                      I am not sure how this switching power supply is set up
                      Could someone please explain how this power supply works
                      Here is the capacitor ESR results
                      (1) 47uf@50 volts 0.46
                      (2) 47uf@50 volts 0.45
                      New 47uf@50 volts 0.35
                      (1) 100uf@25 volts 0.34
                      (2) 100uf@25 volts 0.35
                      New 120uf@50 volts 0.08
                      (1) 220@25 volts 0.13...
                      10-21-2018, 10:02 AM
