Samsung PN43D450A2D, sound no picture.
  • zed310
    • Jan 2015
    • US
    Sound comes on with no picture, Able to hear different inputs, cable box, iPhone, ect…
    Cards look OK, no burns or budging caps, Standby power OK, Plug unit in and turn on via remote VS goes to 207 and then drops, VA goes to 58 and then drops,
    Replaced Y sus and Y buffer, no luck, same issue.
    Replaced logic board, same issue
    Replaced X sus, picture came on for about 5 minutes then went off, now when I apply power it just cycles on then off. When I disconnect the X sus power connector it goes back to the orginal failure mode, sound no picture?
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung PN43D450A2D, sound no picture.
    I fear you may be in vicious cycle. Stop replacing parts. Pull your X-main and Y-main and look for shorts on the boards with a multimeter, specifically the components on the heat sinks. As is the case with many of these Samsungs, your bad boards may be killing your good boards. It sounds like at least your X-main is now faulty.
    Might be useful: https://www.badcaps.net/forum/showth...hlight=Samsung
    LG Plasma Mal-Discharge Correction Service
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • Dodgethis
      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
      by Dodgethis
      Hello all,
      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
      09-11-2024, 07:39 AM
