Samsung SMPS no standby question BN44-00514A (P60SW_CPN)
  • Terryfictv
    • Mar 2011
    • 124
    PN60E8000GF had click-click or totally dead = no standby.
    Apply slight downward pressure on middle heat sink brings all voltages back.
    Power supply appears to be slightly warped....dubious repair. Replace
    the board for a solid, no recall repair ! Or remove all the glue blobs and attempt
    a less expensive as-is fix.
    Terry
    Re: Samsung SMPS no standby question BN44-00514A (P60SW_CPN)
    Can we see the pictures of your board? If you can put pressure on the board to make it function, then it sounds like you have bad connection/s.
    • Terryfictv
      • Mar 2011
      • 124
      Here ya go !
      • nicholas1110
        • Aug 2012
        • 127
        • usa
        I have done a number of these and the 64" versions. Always cold solder joints on qs804.
        I have even had brand new boards from samsung come with bad solder joints on that location as well.
        • nicholas1110
          • Aug 2012
          • 127
          • usa
          This is what it will look like
            Samsung seem to have a lot of cold solder issues. I've seen a 32" LED Samsung (D-series) with cold solder on the bridge rectifier (symptom dead with no power.)
              Yep, very common ring around the collar.
              • Terryfictv
                • Mar 2011
                • 124
                Bingo ! Thanks all ! I removed the BLOB as you can see in the pix.
                Soldered area as needed = fixed !
                  09-07-2024, 05:50 AM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
                • Kaar3l
                  Samsung QLED QE65Q7FNAT only standby light
                  by Kaar3l
                  TV: Samsung QLED QE65Q7FNAT
                  PSU: BN4400940A
                  MB: BN94-12832K
                  I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                  09-24-2024, 01:35 PM
                  09-06-2024, 11:40 PM
