RCA L32HD41 No power when inverter is connected
  • philliesfan30m
    • Aug 2013
    • 542
    The power supply chirps around the transformer when the inverter is plugged in and i get no power at all on the secondary side except a small amount of pulsing voltage that coincides with the chirping but with the inverter disconnected i get all the proper voltages on the secondary side and the tv powers on and off like it should. So i am thinking the power supply isn't driving the transformer properly when it has a load or a short but i checked the caps,diodes,resistors, etc. and i can't seem to find a faulty part or parts that is causing it to shut down when trying to power the inverter. i don't get a flash of backlights and i did check the inverter board also and the fuse is ok and everything checks ok too. so i am sure it is something on the psu but am having a hard time finding it. thanks in advance for any help.
    Re: RCA L32HD41 No power when inverter is connected
    Can you upload good clear pictures of the inverter board?
    • philliesfan30m
      • Aug 2013
      • 542
      pics of inverter board from left to right looking at is as if it was connected. those 2 different caps are like that on other boards as well. the board was never touched as far as i know.
      • CapLeaker
        Leaking Member
        • 8112
        Did you check the inverter board for a short? Sounds like the power supply shuts itself down, when the inverter board is connected.
          Just the inverter board by itself, check the resistance on the two legs of the those two filter caps to see if it shows low resistance, also check the resistance between the S and D of those 4 power MOSFETs.
          • philliesfan30m
            • Aug 2013
            • 542
            well the 2 caps show just continuity it should be higher than that. with the 2 leads together i get about 1.5 ohms and between the leads of the caps is about the same 1.6ohms. 2 mosfets read the same between s and d 1.5 ohms and the other 2 read 95 kohms and 117 kohms those readings are from closest to the connector to furthest away.
              You have bad MOSFETs, the resistance between the two legs of the cap should in the 1000's Ohms range. Remove the suspected MOSFETs and test them off the board. all 4 should be replaced at the same time if you do find the bad one.
              • philliesfan30m
                • Aug 2013
                • 542
                so you as saying remove all 4 and replace all 4 but when i remove them check them so i can find out which 1 or 2 or all are bad to use for someone else in case they run into the same problem? just for reference that board is a SSI320_4UA01 made by samsung which i saw was in a bunch of different brands and models.
                • philliesfan30m
                  • Aug 2013
                  • 542
                  i will do that and report back when tested off the board and thanks so far for the info it is greatly appreciated!
                    Remove the suspected bad one first, if they are bad then I would replace all 4 at the same time plus the two caps. The 4 MOSFETs are set up as a bridge drive.
                    • philliesfan30m
                      • Aug 2013
                      • 542
                      the mosfets on the board are could i replace them with these? they are both off inverter boards and seem to have the same or close to the same parameters and limits but i would like to know your opinion. if not i have other boards that i would rather salvage off rather than buy if i can.
                        The sub will run hotter due to higher Rds and a lot poorer thermal resistance (Ja (Junction to Ambient) of the sub is 62.5 deg. c/W instead of 40 deg. c/W on the original). You can try them for testing.
                        http://www.daycounter.com/Calculator...lculator.phtml
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          ok thanks for the info. when i get them off the board and test them i will use one or 2 of those as a test piece to see if i can get it working. will report back with findings. i just wanna say thanks because i have seen you have helped solve a lot of troubleshooting with people here me included and you are very patient with people that don't have the knowledge of electronics like you do!
                          • philliesfan30m
                            • Aug 2013
                            • 542
                            Re: RCA L32HD41 No power when inverter is connected fix
                            i replaced q106 + q107 and that got it to come back to life. Now i am gonna replace all 4 with the proper mosfets and replace those 2 caps like you suggested. Thanks again for the help i would still be troubleshooting the psu if you wouldn't of helped. And if anyone else has the same problem they now have a fix as well.
                              Great news and thanks for the follow-up on the repair.
                              • survivalbloke
                                Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                by survivalbloke
                                This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                06-25-2025, 12:20 PM
                              • reessi
                                Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                by reessi
                                With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                No corrosion any where!
                                Tried a replacement power button off ebay and the same.
                                Very occasionally it will work with the power button connected!
                                Same results with or without the battery.
                                Can it be a fault with the Audio board or the mainboard?
                                The touch Id assembly connects through the Audio board first then to the Mainboard.
                                Flex...
                                06-26-2024, 03:31 PM
                                09-06-2024, 05:59 AM
                                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 02:15 PM
