Sharp LC-70LE632U 2-5 error
  • danlwalker
    • Jan 2015
    I have a 70in sharp 70LE632U which is a good tv. It caught a xbox remote off a bounce about a month ago and now is giving me error code 2 flash followed by 5 short flash. The service manual says this is a panel power supply problem.
    I have replaced both the t-con and psu boards with exact refurb replacements. I am getting the same error. I have tried power-input-channel down, input-vol down, and channel down-vol down all with no luck.
    After replacing both boards as said above I laid the tv face down on the bed and get back light. Any attempt to move tv it goes back to error 2-5. I slid the tv enough to see some of the screen and noticed that i get vertical multicolored lines going about a third of the way up panel.
    Is this panel shot or can it be repaired?
  • stereojohn
    • Mar 2016
    • 11
    • canada
    Re: Sharp LC-70LE632U 2-5 error
    hi did you try to clean the connections arround the lcd panel the little flexible ribbon cables and the ones from the t-con ? be carefull verry fragile unplug tv before and make sure the are well in place take pictures before so you have a reference .
    if the screen is not craked that could be the problem especially if it was not in a smoke free environement .
    • aaronwt6
      • Apr 2013
      • 855
      • US
      You've got a broken panel on your hands. The lines are a tell tale sign even if the cracks are not visible to the eye.
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • michalk3777@gmail.com
        Sharp Hisense - LC-65N7004U Error codes
        by michalk3777@gmail.com
        Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
        Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
        Regards,...
        12-15-2024, 09:20 PM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Andrew453
        Crestron TPS-2000L with Sharp LQ5AW136R panel
        by Andrew453
        I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
        The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
        Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other...
        01-28-2023, 02:54 PM
