Sharp lc-60e77un
  • Raven1776
    • Jan 2015
    • Usa
    Sharp lc-60e77un
    Last night it turned its self off wont power back on and flashes what i assume is a 2-3 code. The power and opc will light up simultanesly two times and then the opc will light up 3 times. And i cant find any technical information. I have been compulsaive about seeing how things work since birth electronically and mechanically. so i am some what advanced but please explain things in detail. Also is there an app anyone could suggest for iphone to highlight aeras of photos if need be. And i apologize for my earlier post ("i dont understand") i just didnt know how to navigate so sorry.
  • nomoresonys
    • 12276
    • U.S.
    Re: Sharp lc-60e77un
    how tvs work?, read the stickies at the top of the list. then post some good clear pics. of all the boards and one of how they're all connected. as always be careful working with power supply, HIGH VOLTAGE, on primary side, can be deadly.
    • advant
      by advant
      02-03-2020, 12:25 AM
    • sefoster
      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
      by sefoster
      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
      11-20-2022, 09:29 AM
    • gavenb
      Sharp LC-80LE661U 80 inch
      by gavenb
      Hi folks!
      I have a LC-80LE661U that had some interesting issues.
      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
      11-12-2023, 02:05 PM
    • SONY_E-WASTER
      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
      by SONY_E-WASTER
      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
      does...
      12-26-2021, 05:46 PM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
