Samsung LE46M87BD
  • finntricky
    • Jan 2014
    • 449
    Samsung LE46M87BD
    turns it's self off after 10 mins of use, then turns on and off sometimes 2 or more times, then will stay on with out any probs for hours ?
    any ideas on this one.
  • sordids999
    • May 2013
    • 2161
    Re: Samsung LE46M87BD
    pictures of the boards may help
      What have you tested so far?
      • finntricky
        • Jan 2014
        • 449
        Been testing all input on main board, still turns off and on no matter what input is used, but only when using freeview will the picture freeze for upto 30 seconds before turning off,
        Looks like someone has been in here within the last few weeks as had some caps replaced and there clean with no dust,
        I have i soldered them to check and even though that are cheap and nasty caps, that read fine.
        Looking like a main board fault, as all readings from power supply look good,
        I'll get some pics up tomorrow, as can't get them to go up here on the phone,
        • saddle_au
          Waste Warrior
          • 121
          This is what I would look at.
          • finntricky
            • Jan 2014
            • 449
            right, well just got back on here to see if any replys, and yes, but the pic with sergested ideas is well above my head.
            think i'll just put it up for sale,
            thanks for replys guys.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4541
              • Italy - Milan
              One possible cause are cold solder joints, hit slightly the pcb with a screwdriver's handle and moove connectors while ON to see changes.. especially the main board
                09-07-2024, 05:50 AM
              • Egidio85
                Samsung UE55F8000SZ Turns on and off immediately
                by Egidio85
                good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                This defect happens continuously, hearing the classic click of the relay every time.
                Power supply board BN44-00636B
                disconnecting the mains and lamps from the power board always causes the same problem.
                Is it normal that without anything connected this power supply turns on and off cyclically?
                any suggestions on what to check?
                thanks in advance
                03-11-2025, 12:45 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
