LC-60LE640U 2 long 5 short - no picture
  • dontpntpool
    • Dec 2014
    • usa
    Thanks to this thread:
    https://www.badcaps.net/forum/showthread.php?t=35841
    I found the manual and the picture that shows the panel 12v 34pin detection failure.
    I do not know how to go about checking this.
    I bought a replacement powerboard online and it still did not fix the problem, so I am wondering if its the mainboard, but I do not want to waste my money if this wont fix it either.
    I tried getting into a service mode, but can not.
    Freakaft8 has some useful info in this post about the blinking issue but I am not sure how to decipher it
    https://www.badcaps.net/forum/showth...p+reset&page=4
    This post talks about forcing the tv to start.
    https://www.badcaps.net/forum/showth...ht=sharp+reset
    Any help would be appreciated. I am a hobbyist an not a repair person.
  • nomoresonys
    • 12322
    • U.S.
    Re: LC-60LE640U 2 long 5 short - no picture
    if you can, post some good clear pics. of each board and one of how they are all connected, be careful when working with power supply, HIGH VOLTAGE on primary side can be deadly.
    • jm942
      Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
      by jm942
      My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
      I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
      I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
      I did voltage injection on the cpu with 0.7V and i have a current...
      07-11-2024, 05:11 AM
    • Aziz aj
      caps lock 5 long 3 short black screen
      by Aziz aj
      rev-1.0
      input short remove then caps lock 5 long 3 short no output how to solve this problem
      06-08-2024, 07:47 AM
    • lapfix
      Hp 15 capslock 5 long 3 short pb.
      by lapfix
      Hello friends.
      hp 15 -da009nk ...la-g07cp.
      got this lap with capslock 5 long 3 short.
      Try new dump f.48 still the same.
      try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
      ​​​​all voltage are présent.
      pl301/302= 3 and 5 volt.
      pl1001 1.082v.
      pla1 1.033v
      plz1 vcc core 1.058v
      plg1 0v..i think it s the Intel grpahic
      plw1 1.373v.
      plv 3/plv4 vga core 0.918v
      consumption 0.498.
      original bios version f.02..
      any help!...
      02-18-2025, 03:34 AM
    • dfear
      HP Pavilion x360 - 14-ba104na - 3 long and 5 short caps lock code.
      by dfear
      I have a "HP Pavilion x360 - 14-ba104na" in for repair. The caps lock flash 3 long and 5 short.
      HP says this error means:
      The red light blinks three times, and then five, short white light blinks (3 long red, 5 short white)
      This condition indicates that the computer does not detect the processor (CPU).
      Does this mean the CPU is dead or is there another cause for this fault?
      12-10-2022, 06:54 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
