Samsung ln46a530p1fxzc image is NEON
  • tileman
    • Nov 2014
    • 14
    • usa
    hi im new to badcaps very interesting sit, my samsung ln46a530p1fxzc picture looks like the people are neon,imaged attached, pull off ribbon cable from tcon board and cleaned the ends, also when the tv is on a music channel the screen appears to be slightly red any ideas thanks jim
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung ln46a530p1fxzc image is NEON
    It looks like the common AS15-F gamma chip failure. There are many threads on here if you do a search. Can you take a picture of the t-con ?
    • splitcrete
      • Dec 2012
      • 387
      • usa
      I may be your tcon board the as15 chip. Need good clear pictures of tcon.
      • tileman
        • Nov 2014
        • 14
        • usa
        here r pics sorry 4 delay
          Yep, AS15 Gamma Voltage ref IC.
          You can check the DC Voltages at VGMA1 ~ the highest VGMA (looks to #19) and report each reading.
          • tileman
            • Nov 2014
            • 14
            • usa
            i measured voltages on connector VGMA1-8.6 vgma2-9.6
            vgma3-9.9
            vgma4-13
            vgma5-11.05
            vgma6-8.73
            vgma7-11.7
            vgma8-13.16
            vgma9-8.09
            vgma10-7.5
            vgma11-7.5
            vgma12-6.6
            vgma13-12.9
            vgma14-12.1
            vgma15-5.4
            vgma16-5.0
            vgma17-4.1
            vgma18-3.5
            vgma19-3.0
            vgma20-.65
            vgma21-.51
            vgma22-.26
            VCOM-6.54
            AVDD-15.47
              It is bad, either try to replace the IC or replace the board.
              • tileman
                • Nov 2014
                • 14
                • usa
                thanks for your time
                  Board P/N as printed on the bar code sticker:
                  5546t02c01:
                  http://www.shopjimmy.com/auo-55-46t0...-con-board.htm
                  • tileman
                    • Nov 2014
                    • 14
                    • usa
                    thanks Bud im going to order the IC does it mater if the second and third row of numbers on the original IC match the new on or does it only have to be AS15F on the first row
                    • rimwall
                      Sony KD-65x7500D - double image - Tcon or Panel?
                      by rimwall
                      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                      Yesterday, 02:09 AM
                      09-07-2024, 05:50 AM
                    • djdblaster
                      Samsung 70” 4K TU7199 - no image
                      by djdblaster
                      Hi guys, I've got Samsung 70" UHD Crystal 4K TU7199 TV here with backlight present, but no image problem. I've used laptop with HDMI cable to play music off YouTube.
                      TCON board consists of three mini boards: left, middle and right board.
                      Diagnosis:
                      1. when TV is fully assembled, it doesn't turn on fully, rather just boot loops. Backlight comes on for few seconds, no boot sound.
                      2. disconnecting TCON big white cable on the Main board let's TV boot and play music through HDMI.
                      3. TCON cable connected, but left mini board disconnected, TV boots...
                      12-02-2023, 06:01 PM
                      09-06-2024, 11:40 PM
