Main Board Compatability?
  • Ltank
    • Jun 2013
    • 776
    If a main board is not available but they claim the board will work with different models and sizes. Can that be trusted? I hate to spend over a hundred bucks on a board that may not work. If the set is a 50" and they say the board will work with sets bigger and smaller will it be sensed or do I just change advanced settings or change Bios?
  • capkid
    • Oct 2010
    • 1339
    Re: Main Board Compatability?
    If it's ShopJimmy, I'd take the chance. They are not always correct, but returns or exchanges are fairly simple with them.
    LG Plasma Mal-Discharge Correction Service
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Yes and their Customer Service is second to none, if I may add.
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
