Emerson LC320EM82 Black Screen, No Flash
  • aviola7x7
    Alex
    • Apr 2014
    • 28
    • US
    Hey all!
    I've been searching around for a while and can't seem to find a thread anywhere which addresses this issue specifically.
    SYMPTOM:
    Basically, the Emerson LC320EM82 that I have flashes the green indicator light for about 5 seconds after the power button is pressed and then turns to solid red. During this time, the backlight never turns on or flashes at all.
    SOLUTION ATTEMPTS:
    I have checked the resistance of the transformers but everything looks okay-ish. All read between 0.395 to 0.403 kOhm and one reads 0.384 kOhm. I have read I should be getting 4 MOhm so I'm just assuming that the meter's units are off or I am reading it wrong.
    I pulled everything apart and looked at the CCFLs. I've seen bad ones before and all of these look good at a glance. I have verified with the LCD panel removed that none of them turn on when the power button is pressed. I'm assuming that having all of them go bad simultaneously is unlikely and am guessing the problem is somewhere else.
    I have also looked over all of the capacitors and do not see anything that looks bulged.
    At this point, I'm not really sure where to go or what else to check as most people start with the problem of the backlight flashing on then off. I will provide any pictures requested as well as any measurements as soon as I can.
    Thanks very much for your help!
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    Re: Emerson LC320EM82 Black Screen, No Flash
    Pictures would be a good start, PSU, check all your voltages are coming up
    Inverter transformers may be in parallel or have some part in parallel which will mean measuring in-circuit will show different resistances.
    -David VanHorn
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • ekozeko333
      by ekozeko333
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
