Samsung PN58A550S1FXZA turns on with audio chime, no picture.
  • Shinju
    • Mar 2014
    • 1239
    Hello friends!
    I am making an early thread on this, I just got 2 of these units (one with cracked screen parts pig) the other has a perfect screen just no picture.
    I gutted the cracked screen unit took every board but the buffers as the person I got these from told me they powered the unit on with a busted screen and in my short time as a DIY repair geek when someone turns on a PDP with a cracked screen the buffers get shorted or has a high chance to damage them. I didn't have my fluke so I couldn't test.
    Anyway, I have not gotten a chance to tear into the good condition unit yet. I am staring this thread to field what I should do next, it's obvious the unit has a working enough power supply to turn the unit on.
    My question is what next? Is running the panel in its current state to get voltages a bad idea?
    I cannot find a definite answer as to if this is a Y or X failure, I know threads like this are a crap shoot with out photos I will have some tomorrow.
    This panel is a beast, 58" and super heavy much more so then my LG 60" PDP.
    Thanks for the responses in advance!
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung PN58A550S1FXZA turns on with audio chime, no picture.
    All fuses check out good.
    I took a chance and powered on the unit, I hear humming from the x board and a a slight buzzBUZZbuzzBUZZ kind of sounds like oscillation back and fort between low and slightly louder buzzing from the Y board.
    Va/Vs are in spec.
    This is what I am looking at here folks!
    This is a beast
    • Shinju
      • Mar 2014
      • 1239
      VSC -185 spec/ Actual bouncing between -125 to -113. Me thinks the y-main is shot.
      I cannot find VE test point, I see VB and VBf on the xmain.
      • Shinju
        • Mar 2014
        • 1239
        Tried the Ymain out of the cracked panel and same thing, low VSC.
        Think maybe the Lower and Upper drive buffers are shot?
        • Shinju
          • Mar 2014
          • 1239
          I tried to get the test patterns to show up by jumping pin 3-4 removing the LVDS cable and then powering on the unit.
          No dice.
          • Shinju
            • Mar 2014
            • 1239
            since I am waiting for parts on the LG, I would like to see about getting some help tracing down the issue for this Samsung.
            VSC voltage is bouncing all over the place lower then spec, its hitting around. I will be removing the buffers to see if that helps.
            If anyone helping needs more photos I will be posting them tonight.
            • Shinju
              • Mar 2014
              • 1239
              As for anyone who is following this thread i have an update, I have got the TV working, well half of it anyway it seems that the second from the top buffer IC blew out catastrophically causing damage to the upper buffer board on the backside Blowing out a spot circle on the back of the PDP. so I'm going to have to track down another one but the TV seems to run fine with only the lower buffer.
              All voltages are stable and in spec even after being on for 20 min. I was running the test patterns and then decided to switch to video just to see that work and it worked fine.
              • Shinju
                • Mar 2014
                • 1239
                And fixed, I went back to scavenge the busted panel for its y-drive boards and tested them for shorts and they tested out great so I put the upper Ydrive buffer in and its up and running and the picture looks great.
                I do have a new old stock upper Ydrive coming I think I will put that in to be safe but I am sure this buffer would be fine.
                • ALittlebit
                  • Feb 2015
                  • 51
                  • United states
                  Hey pal I just ran across the same problem. TV turns on with chime and no picture. stops halfway through chime and continues to click. Also has LED lights on a board that are flashing non stop and a low sound clicking from another board on the left side of the TV. Can you help me? I am brand new to the repair and multi meter world and need some guidance
                  • whiz62
                    whiz62
                    • Dec 2013
                    • 242
                    • usa
                    way to go! glad you got it going.
                    • ALittlebit
                      • Feb 2015
                      • 51
                      • United states
                      Any advice pals?!
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Start a new thread, Will get more attention Of course upload your own pictures of boards and chassis.
                        • Shinju
                          • Mar 2014
                          • 1239
                          Alittlebit:
                          Best to start your own thread like others have suggested, also please provide us with detailed pictures of the back your TV and voltage readings we will be glad to help you.
                          Let us know!
                          • ALittlebit
                            • Feb 2015
                            • 51
                            • United states
                            Ok I can't figure out how to make a new thread. Feel dumb but I need a guide as I am new to the site. Thanks
                            • whiz62
                              whiz62
                              • Dec 2013
                              • 242
                              • usa
                              Log in and scroll down to video and TV issues and click on that and then
                              you will see new thread. I had same problem.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Highlighted Yellow
                                • ItepK
                                  LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                                  by ItepK
                                  Hello everyone! I've found this television, and I began troubleshooting it.
                                  First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                                  I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                                  After the recapping, all the voltages stableized, however, the issue in the title still remains.
                                  I could...
                                  01-03-2025, 09:01 AM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • magneh
                                  HITACHI U50KA6150 LED TV - Turns on, BKLT ok, no picture
                                  by magneh
                                  Hi there
                                  Got this TV set to check.
                                  The tv turns on ok, I can see on my PC that it detects the screen and I can see it on the screen settings, but theres no image.
                                  Backlight is present. screen not broken or shattered.
                                  Its this clearly a TCON or panel issue?
                                  I dont think it can be a board issue, but im not a TV expert
                                  Any inputs but someone more experiences is welcome before I disassemble the device or try to find a new tcon.
                                  Cheers
                                  09-25-2023, 08:52 AM
