Samsung LN46D630M3FXZA has backlight and sound no video
  • kevinm34232
    • May 2012
    • 1884
    Thought maybe this would be an easy one. After looking at the T-Con I saw the fuse was good and had 12V, checking various components I saw QD2 was shorted and remembered I had seen this before, it's the same model but in a 40":
    https://www.badcaps.net/forum/showth...&highlight=qd2
    That one had a bad panel. Now I'm thinking this one has one too. Is that common that the 40" and 46" panels would have similar failures?
    Panels:
    LTF400HF19 V01
    LTF460HJ05 V01
  • Max514
    Samsung UN55H8000 sound but no backlight no video
    by Max514
    Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
    The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
    I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
    • Unplugging the main board cable at the power supply >>> backlights came on.
    • BLU_ON signal from the
    04-14-2022, 10:34 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • gl4709
    Samsung un55cu7000d with backlight and sound No Video / Picture
    by gl4709
    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
    01-23-2025, 06:21 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
