Samsung UN46B6000VF bad panel or tcon?
  • NUTIN2LUZ
    • 61
    Happy New Year to all!
    I have came across this TV and wanted to know if this could be the panel or tcon board problem. I have a video of it and not pictures. Sorry the video is sideways. Any help would be appreciated. Thank you in advance.
    http://vidmg.photobucket.com/albums/...103_201101.mp4
    Re: Samsung UN46B6000VF bad panel or tcon?
    I've seen this before and it was caused by a panel failure.
    • NUTIN2LUZ
      • 61
      Got it. Thank you tom66.
        09-07-2024, 05:50 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • NWArkGuy
        Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
        by NWArkGuy
        Well, I will be the first to admit that I screwed up...
        In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
        I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
        I have 2 that I have found and have in my possession. ...
        10-12-2023, 10:13 PM
      • KYBOSH
        Samsung UN50TU8000 - Dead Panel Forensic Questions
        by KYBOSH
        I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
        When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
        When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
        Later I checked for shorts on the panel PCB boards but could not find anything.
        When I took a look with the FLIR i noticed the 2 resistors...
        08-10-2024, 08:39 AM
