Samsung UN46B6000VF bad panel or tcon?
  • NUTIN2LUZ
    • 61
    Happy New Year to all!
    I have came across this TV and wanted to know if this could be the panel or tcon board problem. I have a video of it and not pictures. Sorry the video is sideways. Any help would be appreciated. Thank you in advance.
    http://vidmg.photobucket.com/albums/...103_201101.mp4
    Re: Samsung UN46B6000VF bad panel or tcon?
    I've seen this before and it was caused by a panel failure.
    • NUTIN2LUZ
      • 61
      Got it. Thank you tom66.
        09-07-2024, 05:50 AM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • alro7779
        Samsung UN55MU6103F video problem; has colored stripes on the display
        by alro7779
        Hello, everyone!
        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
        09-27-2025, 11:29 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
