Samsung 37" psu question.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    I have a 37" Samsung with the bn44-00262a psu and the connectors on the inverter are burnt beyond repair so I will be repairing the whole board, but its very expensive to buy a new board but I have seen that the bn44-0262b and the board I have are very similar just wandered are they compatible and will work in the tv ?
    Thank you in advance for any reply's.
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Samsung 37" psu question.
    i have one of these if you want it but its carrying faults BN44-00262A H37F1-9SS basically the power supply kept blowing fuses
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Main transistors were leaky replaced them and the 3.2a fuse on the primary and tv is back to life
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
        09-07-2024, 05:50 AM
