Samsung plasma has sound but no picture
  • wsfl321
    • Jan 2015
    • usa
    I have a Samsung FPT5884X/XAA plasma tv that has sound but no picture/menu. The screen gets primed(lit), checked all voltages (which are all good), no burnt components or swollen caps, the logic pcb has 3 led's ( 2 are flashing, 1 on steady). Checked Y buffers for shorts (none found), performed logic pcb test (no test screens). Anybody have experience with this kind of problem? Any ideas? Thanks.
  • wsfl321
    • Jan 2015
    • usa
    Re: Samsung plasma has sound but no picture
    Well fixed the problem.....want to thank everyone for those replies.
    • mmartell
      • Oct 2013
      • 3189
      Well since the world revolves around you I can see where you have been wronged.
      Next time post pics.
      Also don't be a douche and not tell the masses how you fixed your tv by replacing the control board.
      • capkid
        • Oct 2010
        • 1339
        It sometimes helps to bump your thread so people see it. Lots of threads get started on this forum on a daily basis, and threads get pushed to the bottom of the pile very quickly.
        LG Plasma Mal-Discharge Correction Service
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
          I ordered a supposedly β€˜new' Tcon board this time, and
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • Dodgethis
          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
          by Dodgethis
          Hello all,
          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
          09-11-2024, 07:39 AM
