Vizio m370nv lcd led colored vertical lines
  • joseph decreaux
    • 6
    Hi, my vizio m370nv has two vertical lines down the center that are always there. They are very thin but noticeable. When it first turns on the lines are blue but then they turn reddish. What do you think think is the problem and is there anything i can do to fix it. Thanks for the help.
  • joseph decreaux
    • 6
    Re: Vizio m370nv lcd led colored vertical lines
    Anybody?
      I would suggest the LCD panel is defective, unfortunately this would not be economical to fix in most cases.
      Yet another defective LCD panel, sigh.
      • joseph decreaux
        • 6
        Thanks, i hoped that it would not be the lcd.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • brad2157
          Vizio E70-E3 Two white vertical lines
          by brad2157
          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
          Replacement main board - Boots up fine, but starting...
          12-13-2021, 05:11 PM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • rapid911
          Vizio M58Q7 colored horizontal lines
          by rapid911
          Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
          05-28-2023, 04:17 PM
