Phllips 42pf5521d(/10) Madness need help please ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    A month ago I repaired a 42" philips plasma with the 2 fast blink error repaired by replacing the smd capacitors on the 9v line as that rail was running way to low casuing the tv to shutdown, a few weeks later the psu blew the main switching transistors and a smaller bc517 replaced them and psu now turns on and dose the same 2 fast blink error but the 9v rail is good. I have read that the vs is too low but I cant check that rail because the relay shuts off too fast so I need help showing me where to check next because I cant find anything obviously out of order ?
    I also have another one of these coming in as well I will upload pictures when I get back home thank you.
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • lefetylorant
    Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
    by lefetylorant
    Hello Everyone,
    Long story short, I got this unit for very cheap.
    I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
    I've performed some measurements:
    - 20V rail perfectly...
    09-14-2023, 05:05 AM
  • bimole
    Weird behavior on 3.3V rail of a CORSAIR CX600
    by bimole
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
    02-13-2025, 04:49 AM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
