Panasonic LSEP1287 4 blinks
    Hi guys, So im trying to fault find a Panasonic 42" plasma - P42x20b, the 4 blinks tells me its a power board SOS problem, caps look OK, FET's seem to test ok, I have standby voltage, I think i have 15Vdc, Then it shuts down faster than i can measure anything else, i dont really want to pay 350 for a second hand boeard, thanks in advance.
    Re: Panasonic LSEP1287 4 blinks
    Check the SS board Vsus rail, shorted RJP30E4 x 4
      https://www.badcaps.net/forum/showth...hlight=rjp30e4
        OK so i figured the SOS signal is coming from this chip (pin 17 /SOS4_H) ?
        So what signals would generate this alarm if missing ?
          Ok, I'll make it easier for you. The P board is shorted by the SS board(most likely) on the 200v vsus line and triggering the SOS4.
          Disconnect SN2, Sn20, SS11, P35, and the 3 white ribbons at the A board. Turn TV on. Should turn on and stay on and you'll be able to check all voltages if you wish. Don't reconnect any power leads for 5-10 mins, don't run the TV more than 30secs like this.
          If it all goes to plan, this proves A and P boards are ok. Then investigate the SS ( SS11 TPVSUS will be shorted)
            If it all goes to plan, this proves A and P boards are ok. Then investigate the SS ( SS3 will be shorted)
            Thanks. Sorry, I didnt read the reply before posting again
                If your going to run the TV with just the SS isolated, make sure SS11 and SS3 are disconnected. i have managed to blow up a good SN board powering up forgetting to isolate SS3.
                Sometimes both SN and SS blow together due to the SS being connected to the SN
                  Yep, all shorted, no further testing. Sourcing equivalents.
                    Are these suitable replacements ?
                      Nope. Should be able to get the originals or could try IRG7S313UPBF which are only 330V 40A although FGD4536, 360 V PDP Trench IGBT be closer but smaller packaged.
                        ok, thanks, I will have to purchase from eBay for conveinence
                          Bugger ! Replaced the 4 RJP30E4, powered it up, a large buzzing noise occurred, a flash of smoke from the right hand side of the set as you look at from the front, now im getting 8 red flashes :-(
                            Sounds like the SN was bad also. I guess the SS is shorted again too. Did you check out the Sn at all for shorted IGBTs. They're a bugger of a Tv to get right.
                              maybe have a read
                              https://www.badcaps.net/forum/showth...npa5066&page=4
                              may give some clues what can fail.
                                OK so the RJP30E4 's survived, i have thre shorted components on SN
                                DG501RP
                                FU20 TM5S
                                RJP63f3A
                                UT source have all these in stock but something wrong with their payment page, any other reliable sources you could recomend to supply all these in one easy transaction ?
                                  DG501RP
                                  FU20 TM5S
                                  RJP63f3A
                                  I'm rather skeptical that that is all that is blown if the RJP63F3A is shorted. No I have no other source I've tried, there are some kits, but I have no idea if they are complete enough. Which 501RP and 20TM5S blew?
                                    Rjp63 - q661
                                    Fu20 - d481
                                    Dg501- q451
                                    This is turning into something financially uneconomical to repair if this doesn't fix it
                                      Rjp63 - q661
                                      Fu20 - d481
                                      Dg501- q451
                                      Unless you get the bits from china, yes as I have a feeling there's a reasonable chance the SN may still be bad with just those replaced.
                                      maybe PM Flocko if he's around? He's done a few of these sets now and had a couple of failed attempts on the Sn as have I but has more experience.
                                      I have a SN laying around to compare readings to and a SS.
                                        Yeah, with Q661 shorted, you probably have parts faulty in the IC773 circuit as well. You should take tw2005 up on his offer to give you readings from his SN board and compare the readings then to your board. It really helps
