Panasonic LSEP1287 4 blinks
  • Russ300
    • Dec 2014
    • 20
    Hi guys, So im trying to fault find a Panasonic 42" plasma - P42x20b, the 4 blinks tells me its a power board SOS problem, caps look OK, FET's seem to test ok, I have standby voltage, I think i have 15Vdc, Then it shuts down faster than i can measure anything else, i dont really want to pay 350 for a second hand boeard, thanks in advance.
  • tw2005
    • Oct 2011
    • 6457
    Re: Panasonic LSEP1287 4 blinks
    Check the SS board Vsus rail, shorted RJP30E4 x 4
    • tw2005
      • Oct 2011
      • 6457
      https://www.badcaps.net/forum/showth...hlight=rjp30e4
      • Russ300
        • Dec 2014
        • 20
        OK so i figured the SOS signal is coming from this chip (pin 17 /SOS4_H) ?
        So what signals would generate this alarm if missing ?
        • tw2005
          • Oct 2011
          • 6457
          Ok, I'll make it easier for you. The P board is shorted by the SS board(most likely) on the 200v vsus line and triggering the SOS4.
          Disconnect SN2, Sn20, SS11, P35, and the 3 white ribbons at the A board. Turn TV on. Should turn on and stay on and you'll be able to check all voltages if you wish. Don't reconnect any power leads for 5-10 mins, don't run the TV more than 30secs like this.
          If it all goes to plan, this proves A and P boards are ok. Then investigate the SS ( SS11 TPVSUS will be shorted)
          • Russ300
            • Dec 2014
            • 20
            If it all goes to plan, this proves A and P boards are ok. Then investigate the SS ( SS3 will be shorted)
            Thanks. Sorry, I didnt read the reply before posting again
            • tw2005
              • Oct 2011
              • 6457
              • tw2005
                • Oct 2011
                • 6457
                If your going to run the TV with just the SS isolated, make sure SS11 and SS3 are disconnected. i have managed to blow up a good SN board powering up forgetting to isolate SS3.
                Sometimes both SN and SS blow together due to the SS being connected to the SN
                • Russ300
                  • Dec 2014
                  • 20
                  Yep, all shorted, no further testing. Sourcing equivalents.
                  • Russ300
                    • Dec 2014
                    • 20
                    Are these suitable replacements ?
                    • tw2005
                      • Oct 2011
                      • 6457
                      Nope. Should be able to get the originals or could try IRG7S313UPBF which are only 330V 40A although FGD4536, 360 V PDP Trench IGBT be closer but smaller packaged.
                      • Russ300
                        • Dec 2014
                        • 20
                        ok, thanks, I will have to purchase from eBay for conveinence
                        • Russ300
                          • Dec 2014
                          • 20
                          Bugger ! Replaced the 4 RJP30E4, powered it up, a large buzzing noise occurred, a flash of smoke from the right hand side of the set as you look at from the front, now im getting 8 red flashes :-(
                          • tw2005
                            • Oct 2011
                            • 6457
                            Sounds like the SN was bad also. I guess the SS is shorted again too. Did you check out the Sn at all for shorted IGBTs. They're a bugger of a Tv to get right.
                            • tw2005
                              • Oct 2011
                              • 6457
                              maybe have a read
                              https://www.badcaps.net/forum/showth...npa5066&page=4
                              may give some clues what can fail.
                              • Russ300
                                • Dec 2014
                                • 20
                                OK so the RJP30E4 's survived, i have thre shorted components on SN
                                DG501RP
                                FU20 TM5S
                                RJP63f3A
                                UT source have all these in stock but something wrong with their payment page, any other reliable sources you could recomend to supply all these in one easy transaction ?
                                • tw2005
                                  • Oct 2011
                                  • 6457
                                  DG501RP
                                  FU20 TM5S
                                  RJP63f3A
                                  I'm rather skeptical that that is all that is blown if the RJP63F3A is shorted. No I have no other source I've tried, there are some kits, but I have no idea if they are complete enough. Which 501RP and 20TM5S blew?
                                  • Russ300
                                    • Dec 2014
                                    • 20
                                    Rjp63 - q661
                                    Fu20 - d481
                                    Dg501- q451
                                    This is turning into something financially uneconomical to repair if this doesn't fix it
                                    • tw2005
                                      • Oct 2011
                                      • 6457
                                      Rjp63 - q661
                                      Fu20 - d481
                                      Dg501- q451
                                      Unless you get the bits from china, yes as I have a feeling there's a reasonable chance the SN may still be bad with just those replaced.
                                      maybe PM Flocko if he's around? He's done a few of these sets now and had a couple of failed attempts on the Sn as have I but has more experience.
                                      I have a SN laying around to compare readings to and a SS.
                                      • Neelix
                                        • Oct 2013
                                        • 145
                                        • South Africa
                                        Yeah, with Q661 shorted, you probably have parts faulty in the IC773 circuit as well. You should take tw2005 up on his offer to give you readings from his SN board and compare the readings then to your board. It really helps
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
