50ps6000
  • thuss
    • Jul 2012
    • 317
    • uk
    50ps6000
    Hi
    Ive just changed the 3 mosfets, 1 zd (5.6v), 1 ohm resistor on a z sus board for a 50ps3000.
    The tv 50ps6000 as far as I can tell is basically the same as a 50ps3000 but with a different fascia.
    When the tv turns on the screen is really white with the menus hazy accompanied by a high pitched buzz.
    I have checked all the voltages and they seem to be alright apart from the vzb on the z sus which is 198 voltages. When I try to adjust the voltage turning in either direction clock or anti clock I still get 198 volts.
    I thought the vzb should be around 105 volts?
    Any help would be appreciated thanks in advance.
    (btw I still get a pinky picture but what I have noticed as soon as I unplug it, as the voltage drops it goes normal for a second i.e black background with a normal menu displayed)
  • thuss
    • Jul 2012
    • 317
    • uk
    Re: 50ps6000
    I put the following mosfets 20nf20 in positions q13 and q14.
    51n25 in q15, I put a insulating pad with a insulated screw with it.
      Re: 50ps6000
      The Vzb FET is probably shorted, Q13 from memory. It is a linear reg for Vzb supply.
      • thuss
        • Jul 2012
        • 317
        • uk
        Re: 50ps6000
        ok thanks I will replace that later.
        One last thing the grey voltage adjuster next to these mosfets can they be replaced (like for like) because I applied a bit to much pressure and its just completely rotating? I can get it of another lg board
          Re: 50ps6000
          That might be causing the fault. You need to replace it with one of the same spec, should be printed on the back of the device. Different value might not work - can't guarantee it, at least.
          • thuss
            • Jul 2012
            • 317
            • uk
            Re: 50ps6000
            thanks tom66 it was q15
            • MisterAIL
              PS5 digital / No Power / No Beep / Good power supply
              by MisterAIL
              Brought a non functionnal PS5. Apparently only a bad PSU...
              No beep, nothing.
              After some tests i found this :
              - PSU is fine (12 volts stable)
              - 12 volts line is shorted
              - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
              - By the way, nothing change. No signal, no power, no beep.
              Mesuring all rails with my workbench psu (12 volts input)
              - 0.00 amp drawing
              - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
              03-12-2024, 03:24 PM
            • BTubbs200
              Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
              by BTubbs200
              Dell Latitude 5420 P137G
              Board: LA-K491P REV A01
              I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
              Board seems to have no shorts, all power rails are fine and show high resistance.
              When charger is plugged in, voltage is present in 3.3V rail but absent in others....
              01-24-2025, 08:15 PM
              MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
              I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
              I open it up to find non brands name capacitors in it
              I am not sure how this switching power supply is set up
              Could someone please explain how this power supply works
              Here is the capacitor ESR results
              (1) 47uf@50 volts 0.46
              (2) 47uf@50 volts 0.45
              New 47uf@50 volts 0.35
              (1) 100uf@25 volts 0.34
              (2) 100uf@25 volts 0.35
              New 120uf@50 volts 0.08
              (1) 220@25 volts 0.13...
              10-21-2018, 10:02 AM
              I am looking for a transformer secondary of 60 volts @ 30 amp
              The primary voltage is 480 single phase the second voltage needed is 60 volts
              Now it could be 30 volts 0 volts 30 volts preferred
              Or it could be 60 volts 0 volts 60 volts and just use one side of
              Output amp need to be at least 30
              Dose anyone know where I can find one
              This is what is the device I am working on
              The problem with this one is that it is over heating and smelling like it is over heating
              When it has a load on it...
              07-01-2020, 08:14 PM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
