Samsung PS51D550 no picture!
  • Tolmulest
    • 22
    • Eesti
    Re: Samsung PS51D550 no picture!
    Okay i already found a x main replacement board for good price :P
    Is it normal that i hear loud buzzing at the bottom of the screen when i try to turn it on ?
    • mmartell
      • Oct 2013
      • 3189
      With a dead short Vs to ground you should have had a blown fuse. Did you ?
      • Tolmulest
        • 22
        • Eesti
        Well i cant find anything that looks like a fuse :S
        https://flattvparts.co.uk/images/sam...50DH-DF_XM.jpg
        Can you tell where is the fuse?
          You cannot use 720p board in this 1080p set. Be careful: the 720p board has less components and will not work in this TV, this is probably the part you have found, the 1080p board is unobtanium.
          • Tolmulest
            • 22
            • Eesti
            i have a little different board! I took this picture from google bacause they look the same(Maybe little different) to know what does the fuse look like and where its located.
            I have still the original board what came with the tv!
              There is no fuse on these boards. Only a few older plasma TV boards use fuses.
              • Tolmulest
                • 22
                • Eesti
                #27
                So i just need new board?
                  Have you checked for shorts on the current board? Did you find any?
                  You will be lucky to find a replacement board. I think repair is the only way. Many of these are failing recently, probably 5 on here last month alone.
                  • Tolmulest
                    • 22
                    • Eesti
                    #29
                    Where/How should i start looking?
                    From Voltage regulators attached to radiators?
                    • mmartell
                      • Oct 2013
                      • 3189
                      Tom he says in post 18 he has a Vs-ground short on xmain.
                      • Tolmulest
                        • 22
                        • Eesti
                        #31
                        So i measured the resistance between VS and ground again, and on a 2000ohm scale it doesnt show resistance but if i change the range to 200k ohm the resistance keeps rising (Loading caps?)
                          You need to tell us what you mean by "shows resistance", is that a low number few ohms, or slowly increasing, or single "1" meaning open circuit.
                          • Tolmulest
                            • 22
                            • Eesti
                            #33
                            If i measure With 2000ohm range it shows single 1
                            If i switch to 200k ohm range its slowly rising.
                              Ok, that is not shorted, that is measured on X-main from Vs to GND?
                              • Tolmulest
                                • 22
                                • Eesti
                                #35
                                Yes! If i try to turn the tv on i see little white flashing on the bottom of the screen for a second
                                  Are there absolutely no cracks on the screen itself?
                                  • Tolmulest
                                    • 22
                                    • Eesti
                                    #37
                                    There is 1 inside the screen i cant feel it with finger but i can see it.
                                    The tv worked after the crack.
                                      This kills the panel. Sorry, but the crack is triggering a control board shut down due to Y-buffer short. Usually non-repairable.
                                      You can try replacing the Y-buffer board but it will probably die again very quickly
                                      • Tolmulest
                                        • 22
                                        • Eesti
                                        #39
                                        I have already replaces y buffer(its the long one in left side) but still no pic. You sayd ppanel is usually nonrepairable is there a way?
                                          Usually non-repairable in that if it has actually cracked and broken the electrodes then no it's not repairable. In a few cases the crack does not cause any permanent harm but the impact might have damaged a board due to a temporary transient short or panel change.
                                          Unfortunately from what info you have provided this is almost certainly caused by the crack in the panel and it won't be fixable, sorry.
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
