Vizo-A320-A0
  • risien
    • 4
    Vizo-A320-A0
    Start off by saying i know nothing about fixing a tv. But willing to give it a try. This TV just stoped working won't turn on tried different outlets different power cords and nothing (Vizio A320-A0)...I have opened the back and looked at the circuit board. No black marks from shorts or anything...I have noticed looking at other boards on the net that this one doesn't have a Fuse like the rest but a black little circuit. Here is a picture of what mine looks like from another site just like it. Same numbers on the board and everything. Please help i hate to junk this TV.. if i can fix it under 100 bucks..
    • 12330
    • U.S.
    Re: Vizo-A320-A0
    be careful when working with power supply, HIGH VOLTAGE, on primary side, try to only touch what you are testing, look for anything marked F, F=fuse on power supply, test in diode mode, should read 000 or close to it, do this test with tv off and unplugged.
      Re: Vizo-A320-A0
      That black rectangular box is the main AC fuse.
      What tools do you have?
      So there is no any indicator lights on the front at all?
      • risien
        • 4
        Re: Vizo-A320-A0
        I can get a volt meter if i need one and no light what so ever nothing at all...
          Re: Vizo-A320-A0
          You will need at least the digital meter to check the voltages and signals.
            • 12330
            • U.S.
            Re: Vizo-A320-A0
            check your power cord too, never know, sometimes its just that simple.
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • M1NEBLANK SHOW
              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
              by M1NEBLANK SHOW
              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
              Schematic and Boardview here
              04-04-2025, 03:57 PM
            • прямо
              Viper22A 5VSB circuit
              by прямо
              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
              01-13-2024, 07:05 PM
