Horizontal black lines suddenly appeared on 50" LG Plasma
  • zmfc
    • Dec 2014
    Hey all, so I need some advice. The other day when I turned on the 50" LG in my living room, I noticed that there was a bar at the top of the screen that was brighter than the rest across all inputs. At first I thought it might have been some kind of burn in, but upon further inspection I found that the bar on top was actually the correct color and brightness, and that the bottom 4/5ths of the screen was darker than it should have been. I tried using the built-in Picture Wizard function, but it didn't help. Looking closely again, I saw that the picture isn't actually darker, but that every second line of pixels was just a black line, making the picture look dark. It's kind of hard to describe, so here is a picture of how it looks and here is a closeup of the upper left where it transitions from alternating black and colored lines to normal.
    In the research I've done so far, I found a response on justanswer that seems to be just about what I am talking about, but there it mentions that the y buffer board is divided in thirds, and mine seems to be more than just 2/3rds of the screen. Just wanted to confirm with one of you guys before I order a new board. Thanks in advance for your help.
  • zmfc
    • Dec 2014
    Re: Horizontal black lines suddenly appeared on 50" LG Plasma
    Oh, forgot to mention the specific model number is 50PG60-UA. If anyone could help me find which parts I need that would also be great, as my initial searches are turning up a lot of distinct but very similar boards and I'm not sure which is appropriate.
    • mmartell
      • Oct 2013
      • 3189
      Picture of the fault ?
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        It does sound like it is failing buffer boards, a quick look at shopjimmy shows a possibility of several board combos in your tv, It would be a good idea to open the back of the tv and verify the part numbers you need before you order. On your tv there are 2 buffer boards each controls half the screen. On each board are several buffer ics each control about 2" of information
        Liberating magic smoke one part at a time
        • zmfc
          • Dec 2014
          There are two linked in my original post
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • ggil44
            Sony XBR-65X750D Horizontal lines bottom of screen
            by ggil44
            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
            05-30-2023, 07:51 PM
          • CyberNinja
            Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
            by CyberNinja
            First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
            01-10-2021, 09:38 PM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
