Samsung le37r88bd 3 Vertical lines
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, I have here a samsung le37r88bd, It has 3 vertical lines always in the same spot, they start black then change to white a few seconds after being turned on, I'm guessing its a bad pannel but just want to confirm before i strip the boards from it,
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung le37r88bd 3 Vertical lines
    Reseat the lvds, and ribbon cables.
      Definitely a defective LCD panel.
      • Easky15
        • Sep 2013
        • 285
        • Ireland
        thought so, thanks
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          just seen 4 bulged caps.... is it worth tryin to replace them..? could they cause that fault?
            Would not cause this fault.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              You can buy these panels on ebay for £69.99 I have brough three of f the same seller.
              • Easky15
                • Sep 2013
                • 285
                • Ireland
                thanks
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Just rule out that its not lose ribbons before throwing it.
                    "Regional" panel faults are almost never related to individual connectors - LCD or plasma - sadly. The data that is sent in those cables is for large parts of the screen, typically divided into 1/8 or 1/4 portions.
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      A similar issue has been posted as well but also with no actual response ...
                      08-12-2025, 04:19 AM
                    • Stanley1843
                      by Stanley1843
                      06-29-2024, 11:54 AM
                    • x_orange90_x
                      Samsung UN46C8000XFXZA vertical bars/horizontal lines
                      by x_orange90_x
                      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                      09-04-2023, 12:09 PM
                    • polaro
                      Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                      by polaro
                      Greetings,
                      I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                      08-27-2022, 08:46 AM
                      09-07-2024, 05:50 AM
