philips lcd tv powers on ok backlight on sound on no display
  • Shinju
    • Mar 2014
    • 1239
    Re: philips lcd tv powers on ok backlight on sound on no display
    Break it down to panel level and look at the tft board is the only sure Fire way. My guess it's a victim of fluid damage, I had lg/VIZIO panels act like this and there was electrolysis on the TFT board from cleaner damage.
    I wouldn't hook that new t-con up until I verified the txt board. Might fry the new one.
    • shelby5041
      • Feb 2009
      • 1504
      • united states of america usa
      #42
      thank you thats pretty much what bud m said....and yes people do clean tvs with wrong cleaners and ruin boards when cleaner drips down onto the boards....if the board is bad...is this a repairable issue at all??? or tv is trash??
      • shelby5041
        • Feb 2009
        • 1504
        #43
        its just a lot of work tearing down to that level ......
        • Shinju
          • Mar 2014
          • 1239
          I have never been successful at it, I think lookingback (think that's his user name) was fortunate to fix a txt board but it really depends on how bad the damage is and if the electrolysis has damage the fused ribbon cable.
          No idea until you see it. All the ones I have see. Have been pretty extreme.
          • Shinju
            • Mar 2014
            • 1239
            And I feel your pain on breaking down a panel to that level, the ones I did were 42" 55" ugh, had really good luck with 37" and below having good panels.
            At least with a 32" it's relativity small not too many screws!
            • shelby5041
              • Feb 2009
              • 1504
              #46
              why is it that when i disconnect right ribbon on panel to tcon the right screen is bright white
              but if i disconnect both left and right ribbons the screen is black and not full bright white?
              • shelby5041
                • Feb 2009
                • 1504
                #47
                i remmeber when i was doinf lcd monitor repair i had one time screen was bright white 100% when i took it aprt i found that it was a simple fix the lvds came disconnected so i rconected it and it fixed issue....so why in my case if the panel is getting no power from tcon via disconnecting calbes why isnt screen bright white 100% like it was on the right half when i disconnected right side and left the left side in?
                • shelby5041
                  • Feb 2009
                  • 1504
                  #48
                  fyi on my tcon there appears to be 2 lvds type cables going to it and it looks like one has traces going to one half of the chip on board and the other lvds leads to the other half of the chip and then when you look at the other side of chip going to the flat ribbon cables the traces are split in half just like below where the lvds cables connect...see my photo....does that mean anything.....
                  • shelby5041
                    • Feb 2009
                    • 1504
                    #49
                    if i disconnect the lvds that goes to the right side of chip/screen and i unplug the right ribbon i get a picture on left side but kinda distorted like resolution messed up.....and i tried doing this with both ribbons plugged in but again i got no picture on entire screen when right ribbon is connected
                      You can look up the spec sheet of the IC to see how it works.
                        BTW, there are test points (copper pads) with VGH, VGL, VGH_M, VCC.
                        You can take the Voltage readings with all cables connected, and then with one ribbon cable going to the panel one at a time to see what Voltages you get.
                        • shelby5041
                          • Feb 2009
                          • 1504
                          #52
                          ok thanks
                          can either one of you at least let me know if this cannot be a main issue in any way
                          if so then i will tear tv apart since im not going to repair a panel.....but if there is a chance it could be a main issue i will look inot repalcing main
                            I myself never seen the main board causes this kind of symptom.
                            • shelby5041
                              • Feb 2009
                              • 1504
                              #54
                              i see a vgh-m ..but id ont see any others...and its tiny....i se a bunch of v12 14 16 18 20 etc
                              and a couple of vcom
                              all are like tiny coper pads
                              • shelby5041
                                • Feb 2009
                                • 1504
                                #55
                                ok if you have never seen it then thats good enough for me.....thank you
                                  They are around the top right area of the board just below VGH_M.
                                  • shelby5041
                                    • Feb 2009
                                    • 1504
                                    #57
                                    ok vgh-m without right cabe connected it 26v
                                    • shelby5041
                                      • Feb 2009
                                      • 1504
                                      #58
                                      ok i see them will check now without right connected
                                        What do you get with all cable connected? I think some of the Voltage will disappear when all cables connected due to shorts in the panel that kills the Voltages.
                                        • shelby5041
                                          • Feb 2009
                                          • 1504
                                          #60
                                          vgl 5v
                                          vgh 27v
                                          vgh-m 26v
                                          without right ribbon connected
