Panasonic TX-P50XT50B blinks 4 times red LED
  • Damtom
    • 57
    Re: Panasonic TX-P50XT50B blinks 4 times red LED
    Thanks nomoresonys. Ok I will do that
      • 12323
      • U.S.
      tom66 might have a training manual, check the little print under the sentence that says "don't pm me" on his post above, post number 18.
      • Damtom
        • 57
        ok i bought service manual for this panasonic model.
        i attached photo of connector A6 which connect power board and main board, it does look from this schematic like Power SOS signal sends Power board to main board. on pin 8, which is Power SOS voltage, I have 3v(2.96). I think if power board sends SOS signal means it is damaged, am I right ? please confirm this.
        https://picasaweb.google.com/lh/phot...eat=directlink
          • 12323
          • U.S.
          if you upload pics. right here, its a lot better, I clicked your picasa link, they want me to sign in to google etc, if you upload directly here, its faster and easier for us to see them.
          • Damtom
            • 57
            Here is a photo
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • fourroses73
              Panasonic Plasma TX-P46VT20 blinks 10 Times
              by fourroses73
              Hi all folks.
              My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
              Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
              What i have measured:
              Vsus and Vda are ok
              Pin1 of connector P7 : 5V ok
              Pin1 and 9 of connector P6: 16V in place of 15V but...
              12-03-2020, 05:28 PM
            • JarzabekPZ
              HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
              by JarzabekPZ
              I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
              09-18-2025, 08:16 AM
            • brithepi2k
              Samsung UE75TU7020k No picture, Standby blinks 2 times
              by brithepi2k
              My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
              04-23-2025, 10:05 AM
