Panasonic Plasma TX-P46VT20 blinks 10 Times
  • fourroses73
    • Oct 2019
    • CH
    Hi all folks.
    My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
    Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
    What i have measured:
    Vsus and Vda are ok
    Pin1 of connector P7 : 5V ok
    Pin1 and 9 of connector P6: 16V in place of 15V but i find this is ok
    I executed all steps in the Troubleshoting Manual from Panasonic to exclude other boards: Disconnect SC20 to see how many blinks , disconnect A1 , disconnect P6/P7 and many more....with the result : Change A board.
    Im not happy with this answer, i like this TV and i wanna know why its dont work anymore, in the 90s we have repaired every electronic board...
    Have someone any idea ? I remember that in the first time the error whas shown i turn it off and on several times and hes restart normaly.
    Every help is appreciated, and sorry for my bad english, i never learned it.
    PS: The fans i have also cleaned with Qtips. Only the hairdryer i dont have tried already
  • fourroses73
    • Oct 2019
    • CH
    Re: Panasonic Plasma TX-P46VT20 blinks 10 Times
    No one any idea ? ��
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • nick31
      Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
      by nick31
      My Oct 2012 panny plasma quit working yesterday.
      It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
      Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
      I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
      04-21-2021, 09:56 AM
    • Biruslapio
      Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
      by Biruslapio
      Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
      It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
      It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
      02-16-2021, 09:44 PM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • Biruslapio
      Panasonic Plasma 42PV80LB 7 Blinks, VSCN too high
      by Biruslapio
      Hello I'm struggling with this old plasma TV and its SC board, TNPA4393, I've measured the SU/SD buffers, every IGBT and transistors, gate drivers, SMD diodes, optocouplers etc, no shorts or suspecting measurings, at least with they soldered on the board.
      VSUS - 187V
      VDA - 75V
      VE - 130V
      VSET - 320V
      VAD - (-149V)
      16V_F
      5V_F A/B
      15V
      All voltages are normal except for VSCN, which according to the service manual is supposed to be 145V+-4V, it is always 205V.
      VSCN voltage is fixed, generated and measured from VAD...
      06-05-2020, 05:29 AM
