Panasonic TX-P50XT50B blinks 4 times red LED
  • Damtom
    • Dec 2014
    • 57
    Hi all.
    New to forum.
    A while ago I had few TVs to fix and information on this forum helped to solve problems and I noticed that people/ users or I would call them GURUs don't have attitude to less experienced user. That's why I decided to join this forum because I'm that less expierencied user.
    My friend asked to look at Panasonic TX-p50xt50b. After power cut didn't want switch on, no reaction no led, funny enough after few hours comes back to life. From informations found online , IC U203 had to be changed and ordered this one :
    http://www.chsinteractive.co.uk/elec...-spkit2012.htm
    It came yesterday , I changed it , TV started as usual worked for 2 minutes then click noise like relay off sound and since then when I press ON button , red LED blinks 4 times then break and again 4 times.
    Online info suggest power board SOS but on this forum it was proved few times that it doesn't have to be power board.
    Can someone helped me with this issue and guide me what to check first, please ?
  • Ltank
    • Jun 2013
    • 776
    Re: Panasonic TX-P50XT50B blinks 4 times red LED
    With any problems, I always check P.S. Voltages 1st. Then check see if the main board sends command to P.S. to tell it to turn on. If not. Unplug power wait a few minutes. Unplug cable from P.S. to main. See if supply turns on. If not jumper (480 to
    1k ohm resistor ) between the Std by voltage (3.3 or 5vdc depending on set) to PS_ON on P.S. board. If it still does not turn on check other pins that too may need jumping. Check for shorts on P.S. and boards attached to the output
    • Damtom
      • Dec 2014
      • 57
      When I press ON button I can definitely hear all coils noises and then relay sound off after red Led blinks 4 times. I will check all voltages tomorrow as I will have more time.
      Does anyone have a access to service manual for this TV?
        Worth checking if the SC board is shorted... that may cause 4 blinks on this set.
        • Damtom
          • Dec 2014
          • 57
          hi i checked all voltages and only 5v stb is showing 4.88v otherwise all others showing 0.00v
          also i had look for short on power board, there is proper short that even paths are a bit brown(see photo attached).
          As I'm not experienced , can someone tell me if resistor 18 kohms suppose to be damaged, will it show 0.00 kohms or can show also different values, i does show now 5.4kohms.
          i found 2 diodes with no resistance at all, also resistors next to MOSFET transistors are showing different values
          I'm wondering if even is worth to fix or to get used power board from net.
          https://picasaweb.google.com/lh/phot...eat=directlink
            I have the board from the 42" and it has the same browning, I think it's normal.
            • Damtom
              • Dec 2014
              • 57
              What number of your power board , is it Darfon board ??
              But then why is this browning only in this part board ? If that would be due to temperature , it would have browning in other part of board.
              And diodes are knackered too.
                Well, shorts are bad. But it's normal because those resistors get hot in that part of the board.
                • tw2005
                  • Oct 2011
                  • 6458
                  R005,006,007 are in parallel so measured in cct expect 6k ohms
                  I would use diode mode to check diodes and even then you need to know what type of diode it is.
                  Resistors next to mosfets showing different values, means nothing without locations and a schematic. You would have to remove out of cct to be 100% sure if they measure correct.
                  I would say if you can find another PSS board used working cheap enough it may be a smarter option
                    Tw, isn't therea schematic for this board.
                    • tw2005
                      • Oct 2011
                      • 6458
                      yep, a search B159-201 may dig it up. been uploaded a couple of times recently and I've uploaded it to elektotanya
                      • Damtom
                        • Dec 2014
                        • 57
                        Thanks tw2005. I keep forgetting about parrell resistors.
                        I checked diodes in diode mode and shows 0.00 in both direction
                        There is one on eBay for £49.95.
                        • tw2005
                          • Oct 2011
                          • 6458
                          And it's possible they're sitting across a transformer winding which would show short if that's the case
                          • Damtom
                            • Dec 2014
                            • 57
                            There is just that coil. U can see on first and second picture, otherwise there is nothing there.
                              Best to pull them out. Some diodes have the two outer leads electrically connected which is not necessarily a fault.
                              BTW, I remember now, those resistors are for the Ve supply, about 150V unregulated. 18kohm each, they'd dissipate 1.25W a piece. So that explains the board browning around them as that is fairly hot.
                              I guess they use them to give some minimum load to the Ve supply, because otherwise it might vary too much with Vsus/Vda load.
                              I do have the 42" board to make some checks on but it's at home, 300 miles away. Will be back in January if you need some checks done.
                              • Damtom
                                • Dec 2014
                                • 57
                                The only worry I have with buying new power board is that I'm not sure for 100% that current power board is faulty. As I said before there is just 5vstb voltage and others show 0.00v. Shall I give voltages from connector to main board?
                                Fournd manual for b159-201
                                http://elektrotanya.com/panasonic_x5.../download.html
                                • nomoresonys
                                  • 12196
                                  • U.S.
                                  if the only reading you get on power supply is 5 vstb, the problem is probably on your power supply.
                                    Not always, can be that if the main board has not sent power on command that the power board is OK and the main board is bad. Needs to be checked first.
                                    • nomoresonys
                                      • 12196
                                      • U.S.
                                      Indeed, was a quick judgement, needs more checking for sure.
                                      • nomoresonys
                                        • 12196
                                        • U.S.
                                        should he unplug the power on connector from the main board to the power supply and check for power on at the main board? not sure how that works.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • fourroses73
                                          Panasonic Plasma TX-P46VT20 blinks 10 Times
                                          by fourroses73
                                          Hi all folks.
                                          My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
                                          Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
                                          What i have measured:
                                          Vsus and Vda are ok
                                          Pin1 of connector P7 : 5V ok
                                          Pin1 and 9 of connector P6: 16V in place of 15V but...
                                          12-03-2020, 05:28 PM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Samunggg
                                          Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
                                          by Samunggg
                                          I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
                                          I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
                                          09-06-2023, 06:39 PM
