Set factory defaults VIZIO SV422XVT
  • fredrock46
    • May 2014
    • 22
    I finally have my TV powering on again. I bought the main board used so although the TV now comes on I can only see a "No Signal" message. How do I access the setup app. It comes up automatically on a new Vizio TV but this board is used. The user manual gives a good desription of the setup app but nothing about forcing it to come on. Likewise for resetting Factory defaults. It describes how to reset them but only from the on-screen help menu which I can't get to. Anyone know how to do this?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • RRice25541
    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
    by RRice25541
    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
    the color is all outa wack, like the settings have been corupted,
    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
    so
    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
    when i bring up the menu and type the pass codes to access either mode the menu disappears...
    05-13-2022, 10:44 PM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
