Funai lc320em1f
  • Shane711
    • Dec 2014
    • 493
    Re: Funai lc320em1f
    Well I was looking at the one you provided in post #4 on page 38 (10-3) I think is. Not sure if the board is the same but I can't find anything closer. It is in the bottom left corner of the schematic.
    • Shane711
      • Dec 2014
      • 493
      Re: Funai lc320em1f
      If I look through my scraps and find another glass diode with nothing printed on it, do you think that will work?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: Funai lc320em1f
        Hello Shane711
        Can't you add say a 10K resistor in series with it and apply a voltage from a power supply. Measure the volts drop across the diode and this should tell you if it is a schottky diode, standard diode, zenner diode.
        I bought a version of this component tester which works reasonably well.
        http://www.ebay.co.uk/itm/Component-...-/361094470192
        • Shane711
          • Dec 2014
          • 493
          Re: Funai lc320em1f
          OOh, that is beyond my current knowledge. I would have to study this because I am not sure what you are saying. Is there a video I can watch?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Re: Funai lc320em1f
            Hopefully this may help.
            If D1 is a silicon diode, then 1 way round the voltage read by the meter as you increase the power supply from 0 to eg 20V will be 0.4V – 0.7V
            Reverse the diode and the diode will block the voltage so the meter will read approximately what the power supply is set to.
            A schottky diode will be identical to the above except the voltage drop is lower at approximately 0.2 – 0.4 volts
            A zenner diode, the voltage across the diode will increase until it reaches it's zenner voltage as you increase the power supply voltage and then remain at this value while you continue to increase the power supply.
            If you reverse the zenner diode then you will have standard diode voltage drop across it.
              Re: Funai lc320em1f
              The diagram shown as OPEN = Not installed.
              The blank PCB BA94F0F0102 6 can be stuffed to created many PCBA (PCB aseembly) for many models of TVs.
              Does it look like the pads had been touch?
              • Shane711
                • Dec 2014
                • 493
                Re: Funai lc320em1f
                Yes, there was a diode there that someone removed. The solder is melted away with 2 remaining holes. Definitely tampered with. I guess I will have to find the correct schematic for this board in order to figure out what diode is missing. I did not know that saying "OPEN" meant nothing was installed there. You just taught me something new.
                Looks like testing that diode to see what kind it is will not make any difference because I see now the boards must be for 2 different TVs and I can't use the one as a reference for the other. I will just have to put this on the back burner until I find a perfect match.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8331
                  Re: Funai lc320em1f
                  are you sure your TV ends in em1f, not em2f? The em2f had a D609 installed. Was it a glass diode? I think it is a 1ss133. Probably the same on the em1f.
                    Re: Funai lc320em1f
                    We need to see the stickers on the power supply board to get the PCBA number.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8331
                      Re: Funai lc320em1f
                      In this schematic D609 in in there and in the parts list it is a 1SS133. Try a 1n4148... that is a very common diode.
                      • Shane711
                        • Dec 2014
                        • 493
                        Re: Funai lc320em1f
                        To tell you the truth I am not sure what TV it came out of. It was a broken board I had in my pile to be fixed. I usually tag the boards but no tag on it. Since it was closest to a good LC320EM1F board I had, I assumed that's what it was. I took some pictures of the stickers.
                          Re: Funai lc320em1f
                          So the board you are trying to use is not the original one that is installed into the TV. They have so many versions and most of the time goes by the serial number or the series.
                          Can we see the the model number tag on the back of the TV? There may be chassis number on it.
                          • Shane711
                            • Dec 2014
                            • 493
                            Re: Funai lc320em1f
                            If I find out what TV it was intended for I will tag it and use it in the correct TV. But I have all these parts so I just decided to fix it. I have a whole assortment of the common parts that go bad in these Emerson TVs. I keep them in a container separate from all my other components. Getting better and better at it everyday.
                            • DXseekerMO
                              Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                              by DXseekerMO
                              Hello everyone!
                              Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                              Symptoms:
                              1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                              2) TV does not appear to turn on
                              3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                              4) "Power on" terminal on Power Supply has 3.26v
                              5) "A13V" terminals have 12.9v
                              6) Stand-by test jumper on Power Supply has 12.9V
                              7) Optical audio jack on Main Board illuminates
                              8) With stand-by...
                              06-09-2021, 12:19 AM
                            • kotel studios
                              Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                              by kotel studios
                              Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                              State I got it in:
                              Squealing from the PSU
                              After logo I get a blank screen
                              After 10 seconds of having a blank display w/ backlight the TV dies
                              Give it 7-10ish seconds again and it starts to bootloop.
                              What I did so far:
                              Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                              Checked all voltage rails:
                              5VSB - 4.8V
                              AMP+13V - 14.4V
                              13V - 12.98V (in manual 12V)...
                              09-21-2025, 02:00 AM
                            • FriedFred
                              Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
                              by FriedFred
                              Hello, everyone!
                              I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
                              I took out the memory and the battery and the SSD.
                              So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
                              After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
                              After several seconds, the fans switch-off and the board keeps powered...
                              03-08-2025, 04:45 AM
                            • Titus6
                              LG OLE65C1 Stand-By issue
                              by Titus6
                              I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                              However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                              I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                              01-31-2025, 04:01 PM
                            • DXseekerMO
                              Vizio E400i-B2 missing stand-by voltage
                              by DXseekerMO
                              I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
                              So I took some voltage readings upon the original board. Here's what I found:
                              Main caps have 169.9v
                              AC detect voltage is 1.3v
                              None of the MOSFETS appear to be short.
                              The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
                              10-30-2021, 10:19 PM
