vestel software
  • thoma
    • Sep 2012
    • 268
    vestel software
    Hallo to all specialists!
    I read that when the led is blinking at a vestel chassis
    it could be the PSU or a software problem!
    Generally there a lot of memories on the mainboard: there are in some stores
    preprogrammed EPROMS for example used in samsung: in other you can flash it
    over usb!there is a operating software and where the personal usersdata is stored like volume colour etc.So my Question is where can you get the vestel
    software and the prozedure to stop led flashing so that you must not change
    the whole mainboard if there is only a softwareproblem!
    regards toma
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: vestel software
    Depends on What Model Mainboard.....??
    Some are done by USB, while others haven't got a USB.....
    Vestel really ARE CRAP, unfortunately. There appears to be many different F/W that are used on what appears--the same M.B.
    --Like the flashing standby-light can be caused by the PSU. Had just this an hour ago, Original PSU has odd fault so changed it.
    17PW25.3 is original--and the set works (For a while).
    17PW25.4 (only '25' one I can find at the mo, as its gone dark and no power in stores) presents the flashing standby light symptom, although this PSU is known to be good....
    TELEFIX
      Re: vestel software
      Alastair worth noting that not all 17PW25-4s are interchangeable - there's a little jumper on the bottom that'll short the 5V and 3.3V supplies... This usually causes no harm but set will just blink the LED. (Removing the jumper fixes this fault)
      To the OP, it's possible to update the firmware on these but you do require original firmware files. You put them on a blank FAT32 USB stick and hold "OK" on the remote while plugging it in.
      • thoma
        • Sep 2012
        • 268
        Re: vestel software
        Thank you for replies!
        Found http://www.vesteldriver.com/TV_MB70_CORE_UPDATE.html
        is this ok?
        Have I understand right the older LCD-TVs software is in a programmed
        EPROM and the newer onces you can flash over USB
        Does anybody knows other links to download software vestel?
        regards thoma!
        • der1
          • Feb 2015
          Re: vestel software
          When fitting a vestel psu board 17pw26-4 v.1 100409 , white sticker says 20453122 . Bush 40'' tv model number lcd40883f1080p.
          Does the sticker number have to be the same ? also can i use 17pw26-4 v.2 or v3 etc ?
          • DIMITRIO
            • Jul 2017
            • 9
            • GREECE
            Re: vestel software
            Panasonic tx-32gs350e chassis 17mb211 need shredder_usb_update.bin and shredder_usb_update.scr files.please reply ????
            • arizanotlari
              • Nov 2014
              • 158
              • Turkiye
              Re: vestel software
              Try this
              https://yadi.sk/d/oioxsnV9IEwFdA
              https://www.badcaps.net
              • DIMITRIO
                • Jul 2017
                • 9
                • GREECE
                Re: vestel software
                many thanks to ariza notlari ????
                • porfyriadhs
                  Vestel 17mb230 mainboard.No Sound
                  by porfyriadhs
                  Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
                  03-19-2024, 01:12 AM
                • KevinWysocki
                  Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
                  by KevinWysocki
                  Hi there,
                  My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
                  At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
                  After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
                  Flash upgrade didn't seem to work,...
                  08-20-2023, 09:45 AM
                • Aivar1988
                  Can I use different VESTEL panel on mainboard?
                  by Aivar1988
                  Is it possible to replace any part at all in a Vestel TV with a slightly different part?
                  For instance a screen panel - VES650QNTB-2W-U11 <-> VES650QNTS-2D-U11
                  Or a mainboard 17MB130P for any other 17MB130P as long it had the same screen size or even the same screen panel? For example I have a 65" JVC and can I replace it with a 65" Telefunken or Hitachi mainboard. Will I need the new remote aswell? And is it possible to install the JVC firmware onto the new mainboard later?
                  09-14-2021, 12:55 PM
                • l3emarsh
                  Panasonc/vestel 55" 4K HDR Hardware/Software profile needed
                  by l3emarsh
                  I have a Panasonc/vestel 55" 4K HDR TV and I need Hardware/Software profile with the alexa option and satalite option as I have upgraded my cpu main board.
                  If anyone has a copy of the hardware I need PLEASE send me the copy.
                  I can upgrade to Alexa option and Satalite option using Vestel Toolbox v1.1 so that's not essential.
                  Greatfull for any help.
                  Thank you.
                  Lee.
                  01-08-2022, 07:43 AM
                • Tommes
                  Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
                  by Tommes
                  Hey Folks,
                  I'm searching for a Full Flash Recovery Software
                  for my Telefunken D43F287N4CWII
                  Mainboard Vestel 17MB110S
                  Panel: VES430UNDB-2D-N12
                  Productcode: 10119394
                  Does anyone know, where I can get it ?
                  Or is it possible, to extract it from a working mainboard ?
                  The Support Telefunken/Vestel GER couldn't help me.
                  The Vestel TR Support didn't answer my email.
                  History:
                  The main problem with my Telefunken D43F287N4CWII was,
                  it just goes out after a while, sometimes after a...
                  01-04-2022, 09:56 AM
