Panasonic th-p42x10z
  • gunit1234
    • 15
    • New Zealand
    Hi guys! Thanks in advance for the help!
    SYMPTOMS:
    TV was working fine until going into storage in the garage for 6 months. Possibly a little cold and damp, but nothing beyond usual. Now, TV will turn on no problem but upon turning on a second time, will not power up – just green LED then straight to blinking either 2 or 3 red blinks (seems to randomly be either code).
    If I disconnect the TV for 24 hours and let discharge, can then plug in and turn on no problem. But if turning off after 10 sec or half hour (does’t seem to make a difference), will not be able to turn on again. Same blinking red LEDs. Seems to be related to the A-board according to the blink codes.
    SERVICE MANUALS:
    I cannot find the exact service manual. I believe this is an Australia/New Zealand model, maybe named something else in other areas. This is the closest I could find that looked like the same layouts:
    1)
    OR Perhaps
    2)
    WHAT I'VE TRIED:
    1. Done a basic resistance check on the 3 fuses I could find on the power board. Seem kosher.
    2. Looked for bad caps. Can't find any swelling on any board (though I know they're not always visibly broken).
    Also note some cables have already been unplugged so I could check under the A-board.
    I should mention I’m only starting to get into this stuff, have fairly basic knowledge, but am willing to research and learn. That’s why I’m here (but also because I wanna get my TV back haha ).
    THANKSSSSS
    Gil
    • 12323
    • U.S.
    Re: Panasonic th-p42x10z
    did you try here http://elektrotanya.com/?q=showresult&what=sony could be a bad cap.
    • gunit1234
      • 15
      • New Zealand
      Hi there. I'm not sure what you're directing me to. It's not a monitor. It's a plasma TV...
      • jonathon.parker31
        • Jun 2015
        • 3
        • New Zealand
        Hi there i have the exact same tv but with 7 blinking red light when i turn it on, Does anyone know what kind the 3 fuses are on the power board, and do you have to unsolder them to take them out or do they pop out ?, Also wheni turn the tv on i heard 3 clicking noises coming from the back of the tv, Any help would be great thanks.
        • tw2005
          • Oct 2011
          • 6458
          For 7 blinks I'd be investigating Sc, sd, su boards. 3 clicks is normal sequence when the tv is powered, the third is it when it shutsdown with the eeror blinks
          • lambchopsnz
            • Jul 2016
            • 63
            • New Zealand
            Hi everyone I know this an old post but I have the same tv but with led blinking 6 times so I followed the flow chart and replaced the ss board but have got the same blink code 6 flash any thoughts what I should try next.
            Nick
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              The flow chart does not always say something. Did you use the 2011 flow chart or the older ones?
              I would download the service manual here
              On the bottom you will see :
              This file is downloadable free of charge: ...processing...
              Processing will change in "get manual" after a minute.
              Check the blink sequence in that manual! You are in new zealand , its midnight here! I'll check this thread tomorrow morning.
              Hope the manual helps
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Chinese manual , thats not gonna help us! Let me find a better one.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Ok i found the service manual for these models.
                  http://www.toms-service-manuals.com/...&Search=Submit
                  6 blinks --> DRIVER SOS1 , SC ENERGY RECOVERING CIRCUIT and the manual points to SD/SU or SC board.
                  Thats the board on the left hand side. Check if you have a SC50 jumper on the SC board , if so then use a harddisk jumper and remove/isolate the buffer boards from the sc board and turn on the tv. If the TV turns on you probably have bad buffer boards.
                  If you get 7 blinks then the SC board is bad.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Here you will see the SC50 jumper ( If you have one )
                    • lambchopsnz
                      • Jul 2016
                      • 63
                      • New Zealand
                      Cool thanks for the quick reply I'm actually at work at the moment so will reply properly when I get home I had a quick look at that link and I think it's the manual I already got but will check when I'm home.
                      Nick
                      • lambchopsnz
                        • Jul 2016
                        • 63
                        • New Zealand
                        Hi Moreno thanks for your replies i had seen that manual in the link you posted before but i found another one which im sure i found through a link on this forum but i can no longer remember how or where i found it so hopefully this link will show you the one i was using http://www.docfoc.com/2009-pdp-troub...07cp-rev091117 the flow chart i was referring to is on page 41 and 42 so i disconnected sc20 like it says and the led flashes changed from 6 to 8 which refers to ss board...anyhow with that changed i was believing that it was probably the sd/su or sc board and thought i would ask here for any suggestions so thank you and i will do the test for those boards tomorrow.
                        cheers
                        Nick
                        • lambchopsnz
                          • Jul 2016
                          • 63
                          • New Zealand
                          ok so i have now changed the sd/su and sc boards as well as the ss board which i guess leaves the A board...
                          • lambchopsnz
                            • Jul 2016
                            • 63
                            • New Zealand
                            forgot to mention i still have the 6 flash error code.
                            • BigPete
                              Panasonic Heatpump Dryer Repair
                              by BigPete
                              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                              Unfortunately the whole machine has to come apart to fix it.
                              I have...
                              11-01-2025, 06:40 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • AndreStarTrek
                              Cant find the old or new model of the Panasonic CE Z Serie
                              by AndreStarTrek
                              I want to replace the caps of my Sega Dreamcast power supply. But one of them is a 400v 47 CE Z. Some how I cant find that serie or the replacement for that serie.
                              I am not sure if they really are Panasonic. They are all CE with FC and NHG and that are Panasonic models. But all caps are branded with M.
                              Anyone can tell me what serie or replacement serie this is?
                              11-07-2020, 09:03 AM
                            • danielgerman681
                              ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                              by danielgerman681
                              Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                              08-27-2025, 01:17 PM
