Toshiba 40l1333b power on squence any one know ?
  • zomi
    • Nov 2011
    • 511
    Just replaced the main board in the 40l1333b
    And for the life of me I cant remember what the correct power on squence should be
    the tv on start up goes from red to green a few times then powers on and works as normal.
    On power off the red light flashes and it turns off.
    Is this normal, I can't rememb what it should be.
    The last of the vestel tv's I ended up with..
    Re: Toshiba 40l1333b power on squence any one know ?
    That sounds right for a Vestel. The LED colour can vary and sometimes there's only one colour. One Toshiba Vestel junker I had would flash red/green about 5 times when plugged in. It would then go off for 1/2 second and then go red. Once it had done that, you could turn it on by pressing the power button. It would flash red/green about 10 seconds and then turn on.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • slybunda
      Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
      by slybunda
      anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
      also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
      if i were to replace them what should i be looking for?
      they are on the power board of a toshiba (vestel) tv power board.
      pic attached...
      11-13-2023, 06:33 AM
    • cheeky2
      Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
      by cheeky2
      I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
      Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
      The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
      Details:...
      08-17-2023, 04:34 AM
