Vizio E470VL
  • HDjackhammer
    • Dec 2014
    Vizio E470VL
    I have a Vizio E470VL that will not power on. I have replaced both the power supply board and the main board with new ones. Still the same result, only the orange vizio light comes on when plugged in, and dims down immediately. I replaced the power supply board first (0500-0412-1000) and that did not work. Then replaced the main board(3647-0292-0150) and that did not work.
    I ordered the power board from buyqual.com and they sent me a different board (0500-0412-1210) that looks exactly the same as the original. I have spent $250 on boards so far and still no luck. Any help would be appreciated. I am not an electronics expert, just someone trying to fix his TV.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio E470VL
    It's a good idea, to come here first, before buying boards.
    Most likely, one of the boards(or both) is bad.
    I would try, getting back my money, specially for the mainboard.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ermals
      Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
      by ermals
      Hi all!
      I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
      1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
      2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
      3. I've checked voltages...
      08-01-2022, 10:35 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
