I have replaced the inverter board already, still no picture. I can see the picture when I hold a flashlight at an angle to the screen. Any thoughts?
insignia ns-l46q120-10a: no picture only sound
Re: insignia ns-l46q120-10a: no picture only sound
Just to add to my last post, there are 2 mosfets in the middle of the power supply board that may have gotten quite hot. The board around the leads is a darker brown than the rest of the board. Does anyone know what values the leads should read on the mosfets?
by jose6326When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
When i was removing the back cover i heard a rattle.
Removed the metal plate and the heat sink was off (see pic)
would this cause a no picture/image issue?
What is used to put back the heat sink
...2 Photos -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... - Loading...
