LN52A750R1F, Tcon causing set to click on/off once warm.
  • johnboy1313
    • Nov 2012
    • 1959
    I bought this set about six months ago. I put a used Tcon in it and sold it to a friend. Shortly after, it started blacking out every so often. It eventually got to the point that it wasn't watchable. I gave him a different TV yesterday and brought this one back home. After a few minutes, the picture blacks out, followed by the set cycling on/off until you unplug it. When it cycles on, the full chime plays but when it comes time to fire the backlights, it cycles off and starts over. I determined that unplugging the tcon would stop the cycling and would allow the set to come on and stay on. With the tcon connected but the LCD disconnected, the set still cycles. I feel this rules out the LCD. I recapped the PSU to be sure it wasn't caused by bad 16V 1000uf caps being loaded down. It still cycles. The tcon doesn't feel overly hot. I'm going to go over it for cracked solder joints this morning. Is there something else I should inspect?
    Re: LN52A750R1F, Tcon causing set to click on/off once warm.
    I had a 40" B650 with a similar symptom, t-con shorted causing set to cycle. Never had it occur while running, that set refused to boot entirely.
    • johnboy1313
      • Nov 2012
      • 1959
      That's what's making me suspect a solder joint.
        Maybe worth checking 13V rail whilst set is running, see if it drops under load. Could also try hooking a car brake light to the 13V rail to load it down, simulating a T-con board load.
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
