test y buffer for short? part# ebr38447802
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: test y buffer for short? part# ebr38447802
    how do i identify a floating ground pin?....the pins just say gnd on the buffer board
    i used the large copper pads that the screws mount to....
      Those ones, there should be one at the top of the board (that's VFG+VSCAN) and two in the middle, which is the floating ground.
      There are also sometimes ordinary ground screws - they go into the chassis - don't use them.
      • shelby5041
        • Feb 2009
        • 1505
        im testing the boards for short out of tv..there is no locations that you mentioned on my y buffer board
          Please supply a picture of your board showing where you are testing as I am now thoroughly lost.
          • shelby5041
            • Feb 2009
            • 1505
            pic is in this post along with part #
            u can look it up on ebay or shop jimmy
            i cant send another pic now im mobile
            • shelby5041
              • Feb 2009
              • 1505
              #26
              i want to thank everyone who helped me on this issue
              using the various testing methods i have proven that in fact all my upper y boards bought on ebay and shop jimmy are are shorted 100%
              after doing the tests i marked the chips that tested shorted and since the boards are no good in my mind i decided to take it one step further...i took the heat sinks off to see what the chips looks like and see my photos.....everyone that tested shorted were broken or burnt or holes.....see brown spots under heat sinks....
              so this thread is officially over.....
              thank you again..........the tests work.....and pictures say it all.....photos dont lie...as much as the ebay sellers want to say their board is good...its all BS...i have proven them wrong...
              • shelby5041
                • Feb 2009
                • 1505
                #27
                oh well cant get the chip off.........heat gun wont melt the leaded solder........
                • shelby5041
                  • Feb 2009
                  • 1505
                  #28
                  uh oh.....it came off but all of the pads came off with it........i figured it wouldnt work....worth a try
                  • tw2005
                    • Oct 2011
                    • 6458
                    So it is looking that just the buffers were stopping you fixing this which I was starting to suspect. It would be nice to see these working but at how much more expense or bad luck?
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #30
                      still not sure whats wrong with tv.....the buffer being bad should have triggered a black display and it didnt so i suspect the tv has other issues
                      the y buffer upper was shorted yes but then why wouldnt the top half of the display be black???
                      its not black its very bright pink and white....so im confused
                      • tw2005
                        • Oct 2011
                        • 6458
                        Well if it was shorting out , may have then dragged the Ysus voltages / signals down and hence bad image / maldischarge. I've seen shorted buffers cause a messed up image in a Lg. i think that's where I started on first impression. I would have thought with no top and bottom only you may have an image but not sure if that's true or not. I guess if you had not put so much $ in to it it may be worth going on but they're not a brand I chased for projects, except if virtually free.
                        I can't help guide you really anymore, we all learn along the way, winners & losers. these just turned out to be unlucky for you.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          thanks
                          i am going to repair this tv no matter cost....i dont care about cost anymore im beyond caring i have way too many hours into this tv to walk away now
                          i appreciate your help....i bought a upper y on ebay that is not shorted and i will try to intstall it without bottom buff connected and also disconnect z and see how tv acts
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #33
                            i installed 4 diff y boards and tv had exact same problem so im going to assume the y boards are all good since all 4 cant all have same problem....the thing now is either the panel is bad or the upper buffer was the issue or the z board is bad
                            • Hemant007
                              • Apr 2020
                              • 14
                              • United Kingdom
                              #34
                              Hi, I am trying to test Y buffer, can you please advise on selecting ground pin, I don't see any labelled as ground. Attached is connector photo on Y buffer board, thank you
                              • G-Sting
                                iPad Pro A1876 SHORT Part Identify Help Needed
                                by G-Sting
                                So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                SO My main concern is what part should i order what should i search the name for ?
                                on Ipad...
                                05-15-2025, 09:30 AM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • vbogoev
                                Lenovo S6000 won't turn on. Data recovery needed.
                                by vbogoev
                                Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                Code:
                                [PWRAP] pwrap_init_preloader
                                [PWRAP] pwrap_init
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                [PMIC_WRAP]wrap_init pass,the return
                                06-20-2023, 06:36 AM
                              • Stephen
                                MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                by Stephen
                                I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                02-06-2025, 12:03 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
